I am using the display with my Raspberry Pi 4b. It runs with raspberry pi OS.
The screen works fine, but when I try to double tap, I can't open any folders or applications.
Is it possible to enable this?
Kind regards
Thomas
7inch HDMI HD Touchscreen - double tap
Only the Bullseye system supports double-tap on the screen. Bookworm does not support double-tap, and there is currently no way to enable it.
The double-tap feature is supported only on the Bullseye system. Unfortunately, Bookworm does not support double-tap, and there is currently no way to enable this feature on Bookworm.Luckfox Taylor wrote: ↑2024-06-17 6:25 Only the Bullseye system supports double-tap on the screen. Bookworm does not support double-tap, and there is currently no way to enable it.
In the kernel updated on October 22, the double-click function was added to the Bookworm system. Please check:
https://downloads.raspberrypi.com/raspi ... _notes.txt
