Hi All
I need a bit of help . I want to infer an external rtsp stream using yolo5 on my pico max. What i have at the moment is use the RKNN Model Inference Test and ffmpeg to grab images and put on the sd card. My problem is that it is very slow and only infers ever second and i would like to get to may 10 frames.
Anyone know of a better way to do this. I tried the opencv-mobile but it does not support RTSP. Python3 in buildroot does not have a opencv module either.
I think i am stuck with trying to do it with RKNN Model Inference but i cant figure out how to pull a rtsp stream without ffmepg libarys or Opencv librarys.
Any help would be great
Thanks
Robby
object detect on external rtsp feed pic max
Hi Guys
Hope this helps other people. I have managed to get an rtsp stream on my pico MAX using the following. The next step is to add the RKNN infering but I dont have enough C skills so if anyone can build on this or add, please go ahead.
I could be wrong but this is the closest i have come so far.
I suggest first doing the RKNN tutorial and making a basic cc program first to understand the build script.
First you need to buildroot and add :
ffmpeg
jpeglib
Then build a new image for you pico. I have only done this on the Pico Max.
Then i used the RKNN Model Inference tutorial and build my own C program.
Here is a copy of the CmakeLists.txt
And here is a copy of my .cc file.
Hope this helps someone
Thanks
Robby
ffmpeg
jpeglib
cmake_minimum_required(VERSION 3.4.1)
project(apex)
set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -Wl,--allow-shlib-undefined")
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++11 -Wl,--allow-shlib-undefined")
# install target and libraries
set(CMAKE_INSTALL_PREFIX ${CMAKE_SOURCE_DIR}/install/apex_${CMAKE_SYSTEM_NAME})
set(CMAKE_SKIP_INSTALL_RPATH FALSE)
set(CMAKE_BUILD_WITH_INSTALL_RPATH TRUE)
set(CMAKE_INSTALL_RPATH "${CMAKE_INSTALL_PREFIX}/lib")
# rknn api
set(RKNN_API_PATH ${CMAKE_SOURCE_DIR}/../../../runtime/RV1106/${CMAKE_SYSTEM_NAME}/librknn_api)
set(RKNN_RT_LIB ${RKNN_API_PATH}/armhf/librknnmrt.so)
include_directories(${RKNN_API_PATH}/include)
include_directories(${CMAKE_SOURCE_DIR}/../../3rdparty)
include_directories(/home/Projects/luckfox/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/output/host/arm-buildroot-linux-uclibcgnueabihf/sysroot/usr/include)
link_directories(/home/Projects/luckfox/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/output/host/arm-buildroot-linux-uclibcgnueabihf/sysroot/usr/lib)
# Apex
include_directories(${CMAKE_SOURCE_DIR}/include)
add_executable(apex
src/main.cc
src/postprocess.cc
target_link_libraries(apex avformat avcodec avutil jpeg
${RKNN_RT_LIB}
install(TARGETS apex DESTINATION ./)
install(PROGRAMS ${RKNN_RT_LIB} DESTINATION lib)
install(DIRECTORY model DESTINATION ./)
#include "rknn_api.h"
#include <float.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/time.h>
#include <vector>
#include <iostream>
#include <filesystem>
#include <string>
#include <stdio.h>
#include <dirent.h>
#include <string.h>
#include <unistd.h>
#include <jpeglib.h>
extern "C"{
#include <libavformat/avformat.h>
#include <libavcodec/avcodec.h>
// #define STB_IMAGE_IMPLEMENTATION
// #include "stb/stb_image.h"
// #define STB_IMAGE_RESIZE_IMPLEMENTATION
// #include <stb/stb_image_resize.h>
// #include "postprocess.h"
// #define PERF_WITH_POST 1
//Using Hikvision Camera
#define RTSP_URL "rtsp://xxx:xxx@10.0.0.86:554/Streaming/Channels/102"
Main Functions
int main() {
av_register_all();
// Initialize network components (needed for RTSP)
avformat_network_init();
AVFormatContext *formatContext = avformat_alloc_context();
// Open the RTSP stream
if (avformat_open_input(&formatContext, RTSP_URL, NULL, NULL) != 0) {
fprintf(stderr, "Error opening RTSP stream\n");
return 1;
// Find stream information
if (avformat_find_stream_info(formatContext, NULL) < 0) {
fprintf(stderr, "Error finding stream information\n");
avformat_close_input(&formatContext);
avformat_network_deinit();
return 1;
// Find the first video stream
int videoStreamIndex = -1;
for (int i = 0; i < formatContext->nb_streams; i++) {
if (formatContext->streams[i]->codecpar->codec_type == AVMEDIA_TYPE_VIDEO) {
videoStreamIndex = i;
break;
if (videoStreamIndex == -1) {
fprintf(stderr, "Error finding video stream\n");
return 1;
AVCodecContext *codecContext = avcodec_alloc_context3(NULL);
avcodec_parameters_to_context(codecContext, formatContext->streams[videoStreamIndex]->codecpar);
AVCodec *codec = avcodec_find_decoder(codecContext->codec_id);
if (!codec) {
fprintf(stderr, "Error finding codec\n");
avcodec_free_context(&codecContext);
return 1;
if (avcodec_open2(codecContext, codec, NULL) < 0) {
fprintf(stderr, "Error opening codec\n");
return 1;
AVPacket packet;
av_init_packet(&packet);
AVFrame *frame = av_frame_alloc();
printf("Ready to receive frames...\n");
while (av_read_frame(formatContext, &packet) >= 0) {
if (packet.stream_index == videoStreamIndex) {
// Decode video frame
if (avcodec_send_packet(codecContext, &packet) == 0) {
while (avcodec_receive_frame(codecContext, frame) == 0) {
// Print frame information
printf("Received frame: width=%d, height=%d\n", frame->width, frame->height);
// Save the frame to an image file (you can implement this function)
//save_frame_to_image(frame->data[0], frame->linesize[0] * frame->height, frame->width, frame->height);
// Sleep for a short duration (adjust as needed)
usleep(10000); // 10ms
av_packet_unref(&packet);
printf("Finished receiving frames...\n");
av_frame_free(&frame);
// Clean up
Thanks
Robby
Congratulations on successfully obtaining an RTSP stream on your pico MAX! I am sure that the method you've shared will be of great help to many others in the community.
