How to develop a program that recognizes QR codes using zxing-cpp?
  • I compiled and ran the QR code recognition program using zxing-cpp 2.2.1 through the following procedures.
    ENV : WSL Ubuntu 22.04
    ~/luckfox/dev$ mkdir barcode
    ~/luckfox/dev$ cd barcode
    ~/luckfox/dev/barcode$ git clone https://github.com/zxing-cpp/zxing-cpp.git
    ~/luckfox/dev/barcode$ cd zxing-cpp
    ~/luckfox/dev/barcode/zxing-cpp$ nano luckfox_toolchain.cmake
    set(CMAKE_SYSTEM_NAME Linux)
    set(CMAKE_SYSTEM_PROCESSOR arm)
    set(CMAKE_C_COMPILER /home/smart/luckfox/luckfox-pico/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin/arm-rockchip830-linux-uclibcgnueabihf-gcc)
    set(CMAKE_CXX_COMPILER /home/smart/luckfox/luckfox-pico/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin/arm-rockchip830-linux-uclibcgnueabihf-g++)
    set(CMAKE_CXX_STANDARD 17)
    set(CMAKE_CXX_STANDARD_REQUIRED ON)
    set(CMAKE_FIND_ROOT_PATH /home/smart/luckfox/luckfox-pico/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin)
    set(CMAKE_FIND_ROOT_PATH_MODE_PROGRAM NEVER)
    set(CMAKE_FIND_ROOT_PATH_MODE_LIBRARY ONLY)
    set(CMAKE_FIND_ROOT_PATH_MODE_INCLUDE ONLY)
    set(CMAKE_FIND_ROOT_PATH_MODE_PACKAGE ONLY)
    ~/luckfox/dev/barcode/zxing-cpp$ nano CMakeLists.txt
    include(luckfox_toolchain.cmake)
    cmake_minimum_required(VERSION 3.15)
    project(ZXing)
    option (ZXING_READERS "Build with reader support (decoders)" ON)
    set    (ZXING_WRITERS "ON" CACHE STRING "Build with old and/or new writer (encoder) backend (OFF/ON/OLD/NEW/BOTH)")
    option (ZXING_USE_BUNDLED_ZINT "Use the bundled libzint for barcode creation/writing" ON)
    option (ZXING_C_API "Build the C-API" OFF)
    option (ZXING_EXPERIMENTAL_API "Build with experimental API" OFF)
    option (ZXING_EXAMPLES "Build the example barcode reader/writer applications" ON)
    option (ZXING_BLACKBOX_TESTS "Build the black box reader/writer tests" OFF)
    option (ZXING_UNIT_TESTS "Build the unit tests (don't enable for production builds)" OFF)
    option (ZXING_PYTHON_MODULE "Build the python module" OFF)
    set    (ZXING_DEPENDENCIES "AUTO" CACHE STRING "Fetch from github or use locally installed (AUTO/GITHUB/LOCAL)")
    if (WIN32)
        option (BUILD_SHARED_LIBS "Build and link as shared library" OFF)
    else()
        option (BUILD_SHARED_LIBS "Build and link as shared library" ON)
    endif()
    if (MSVC)
        add_definitions (-DUNICODE -D_UNICODE -D_CRT_SECURE_NO_WARNINGS)
        option (ZXING_LINK_CPP_STATICALLY "MSVC only, link standard library statically (/MT and /MTd)" OFF)
        if (LINK_CPP_STATICALLY OR ZXING_LINK_CPP_STATICALLY)
            set(CMAKE_MSVC_RUNTIME_LIBRARY "MultiThreaded$<$<CONFIG:Debug>:Debug>")
        endif()
    endif()
    if (NOT CMAKE_BUILD_TYPE)
        set (DEFAULT_BUILD_TYPE "Release")
        message (STATUS "Setting build type to '${DEFAULT_BUILD_TYPE}' as none was specified.")
        set (CMAKE_BUILD_TYPE "${DEFAULT_BUILD_TYPE}" CACHE STRING "Choose the type of build." FORCE)
        set_property (CACHE CMAKE_BUILD_TYPE PROPERTY STRINGS "Debug" "Release" "MinSizeRel" "RelWithDebInfo")
    endif()
    # provide backward compatibility for deprecated BUILD_... options
    if (DEFINED BUILD_READERS)
        set (ZXING_READERS ${BUILD_READERS})
    endif()
    if (DEFINED BUILD_WRITERS)
        set (ZXING_WRITERS ${BUILD_WRITERS})
    endif()
    if (DEFINED BUILD_EXAMPLES)
        message (WARNING "zxing-cpp cmake options BUILD_... are deprecated, please switch to ZXING_... variant")
        set (ZXING_EXAMPLES ${BUILD_EXAMPLES})
    endif()
    if (DEFINED BUILD_PYTHON_MODULE)
        set (ZXING_PYTHON_MODULE ${BUILD_PYTHON_MODULE})
    endif()
    if (DEFINED BUILD_DEPENDENCIES)
        set (ZXING_DEPENDENCIES ${BUILD_DEPENDENCIES})
    endif()
    if (NOT (ZXING_READERS OR ZXING_WRITERS))
        message(FATAL_ERROR "At least one of ZXING_READERS/ZXING_WRITERS must be enabled.")
    endif()
    set(ZXING_WRITERS_LIST OFF ON OLD NEW BOTH)
    set_property(CACHE ZXING_WRITERS PROPERTY STRINGS ${ZXING_WRITERS_LIST})
    if(NOT ZXING_WRITERS IN_LIST ZXING_WRITERS_LIST)
        message(FATAL_ERROR "ZXING_WRITERS must be one of ${ZXING_WRITERS_LIST}")
    endif()
    set(ZXING_DEPENDENCIES_LIST AUTO GITHUB LOCAL)
    set_property(CACHE ZXING_DEPENDENCIES PROPERTY STRINGS ${ZXING_DEPENDENCIES_LIST})
    if(NOT ZXING_DEPENDENCIES IN_LIST ZXING_DEPENDENCIES_LIST)
        message(FATAL_ERROR "ZXING_DEPENDENCIES must be one of ${ZXING_DEPENDENCIES_LIST}")
    endif()
    if (NOT DEFINED CMAKE_CXX_STANDARD)
        set (CMAKE_CXX_STANDARD 17)
    endif()
    if (NOT DEFINED CMAKE_CXX_EXTENSIONS)
        set (CMAKE_CXX_EXTENSIONS OFF)
    endif()
    add_subdirectory (core)
    enable_testing()
    include(zxing.cmake)
    if (ZXING_EXAMPLES)
        add_subdirectory (example)
    endif()
    if (ZXING_BLACKBOX_TESTS)
        add_subdirectory (test/blackbox)
    endif()
    if (ZXING_UNIT_TESTS)
        add_subdirectory (test/unit)
    endif()
    if (ZXING_PYTHON_MODULE)
        add_subdirectory (wrappers/python)
    endif()
    if (ZXING_C_API)
        add_subdirectory (wrappers/c)
    endif()
    As shown in the code above, "include(luckfox_toolchain.cmake)" was added to the first part of CMakeLists.txt.
    ~/luckfox/dev/barcode/zxing-cpp$ mkdir build
    ~/luckfox/dev/barcode/zxing-cpp$ cd build
    ~/luckfox/dev/barcode/zxing-cpp/build$ cmake ..
    ~/luckfox/dev/barcode/zxing-cpp/build$ make help
    ~/luckfox/dev/barcode/zxing-cpp/build$ make ZXing
    ~/luckfox/dev/barcode/zxing-cpp/build$ make ZXingReader
    ~/luckfox/dev/barcode/zxing-cpp/build$ cd core
    ~/luckfox/dev/barcode/zxing-cpp/build/core$ scp libZXing.so.2.2.1 [email protected]:/root
    ~/luckfox/dev/barcode/zxing-cpp/build/core$ cd ..
    ~/luckfox/dev/barcode/zxing-cpp/build$ cd example
    ~/luckfox/dev/barcode/zxing-cpp/build/example$ scp ZXingReader [email protected]:/root
    Execute the following command in LuckFox Pico Max.
    [root@luckfox root]$ ln -s libZXing.so.2.2.1 libZXing.so.3
    [root@luckfox root]$ ln -s libZXing.so.3 libZXing.so
    [root@luckfox root]$ mv lib* /usr/lib
    Recognize barcodes as follows:
    [root@luckfox root]$ ./ZXingReader opencv_cap1.bmp
  • Hi,
    I’d like to do the same. Is the codes above working as it intended? How about grabbing a frame from camera directly?
  • Hi,
    I've made it using the information you've provided, thank you very much.
    Using opencv-mobile, I captured using camera and able to recognize barcode in the view.
