Luckfox-pico mini B 的Build.sh 编译不过是什么问题?
  • 您好,您提供的LOG并不能真正反应编译不通过的原因,请提供更多的上下文信息或长截图,无关的编译信息可以省略
  • vy@vy-virtual-machine:~$ cd luckfox-pico
    vy@vy-virtual-machine:~/luckfox-pico$ sudo ./build.sh lunch
    [sudo] vy 的密码:
    You're building on Linux
    Lunch menu...pick the Luckfox Pico hardware version:
    选择 Luckfox Pico 硬件版本:
    [0] RV1103_Luckfox_Pico
    [1] RV1103_Luckfox_Pico_Mini_A
    [2] RV1103_Luckfox_Pico_Mini_B
    [3] RV1103_Luckfox_Pico_Plus
    [4] RV1106_Luckfox_Pico_Pro_Max
    [5] RV1106_Luckfox_Pico_Ultra
    [6] RV1106_Luckfox_Pico_Ultra_W
    [7] custom
    Which would you like? [0~7][default:0]: 2
    Lunch menu...pick the boot medium:
    选择启动媒介:
    [0] SD_CARD
    [1] SPI_NAND
    Which would you like? [0~1][default:0]: 0
    Lunch menu...pick the system version:
    选择系统版本:
    [0] Buildroot(Support Rockchip official features)
    [1] Ubuntu(Support for the apt package management tool)
    Which would you like? [0~1][default:0]: 1
    [build.sh:info] Lunching for Default BoardConfig_IPC/BoardConfig-SD_CARD-Ubuntu-RV1103_Luckfox_Pico_Mini_B-IPC.mk boards...
    [build.sh:info] Running build_select_board succeeded.
    [build.sh:info] /home/vy/luckfox-pico/sysdrv/tools/board/ubuntu is empty or does not exist, updateing submodule!
    Check [OK]: dtc --version
    Please install makeinfo first
    sudo apt-get install texinfo
    Check [OK]: gperf --version
    Check [OK]: dpkg --list |grep g++-.*-multilib
    Check [OK]: dpkg --list |grep gcc-.*-multilib
    Check [OK]: make -v
    GLOBAL_PARTITIONS: 0x8000@0x0(env),0x80000@0x8000(idblock),0x40000@0x88000(uboot),0x2000000@0xC8000(boot),0x20000000@0x20C8000(oem),0x10000000@0x220C8000(userdata),0x180000000@0x320C8000(rootfs),-@0x1B20C8000(media)
    [build.sh:info] Partition Filesystem Type Configure: rootfs@IGNORE@ext4,userdata@/userdata@ext4,oem@/oem@ext4
    [build.sh:info] switch to DTS: /home/vy/luckfox-pico/sysdrv/source/kernel/arch/arm/boot/dts/rv1103g-luckfox-pico-mini-b.dts
    [build.sh:info] switch to kernel defconfig: /home/vy/luckfox-pico/sysdrv/source/kernel/arch/arm/configs/luckfox_rv1106_linux_defconfig
    [build.sh:info] The root file system used is not buildroot
    TARGET_ARCH=arm
    TARGET_UBOOT_CONFIG=luckfox_rv1106_uboot_defconfig rk-emmc.config
    TARGET_SPL_CONFIG=
    TARGET_KERNEL_CONFIG=luckfox_rv1106_linux_defconfig
    TARGET_KERNEL_DTS=rv1103g-luckfox-pico-mini-b.dts
    TARGET_RECOVERY_CONFIG=
    TARGET_RAMBOOT_CONFIG=
    ============Start building sysdrv============
    make: Entering directory '/home/vy/luckfox-pico/sysdrv'
    ==sysdrv== build uboot
    make[1]: Entering directory '/home/vy/luckfox-pico/sysdrv/source/uboot/u-boot'
    # configuration written to .config
    Using .config as base
    Merging ./arch/../configs/rk-emmc.config
    Value of CONFIG_ROCKCHIP_EMMC_IOMUX is redefined by fragment ./arch/../configs/rk-emmc.config:
    Previous value: # CONFIG_ROCKCHIP_EMMC_IOMUX is not set
    New value: CONFIG_ROCKCHIP_EMMC_IOMUX=y
    # merged configuration written to .config (needs make)
    scripts/kconfig/conf --oldconfig Kconfig
    make[1]: Leaving directory '/home/vy/luckfox-pico/sysdrv/source/uboot/u-boot'
    pushd /home/vy/luckfox-pico/sysdrv/source/uboot/u-boot;/home/vy/luckfox-pico/sysdrv/source/uboot/u-boot/make.sh --spl-new CROSS_COMPILE=arm-rockchip830-linux-uclibcgnueabihf-;popd
    /home/vy/luckfox-pico/sysdrv/source/uboot/u-boot /home/vy/luckfox-pico/sysdrv
    scripts/kconfig/conf --silentoldconfig Kconfig
    CHK include/config.h
    CFG u-boot.cfg
    GEN include/autoconf.mk.dep
    CFG spl/u-boot.cfg
    CFG tpl/u-boot.cfg
    GEN spl/include/autoconf.mk
    GEN tpl/include/autoconf.mk
    CHK include/config/uboot.release
    CHK include/generated/timestamp_autogenerated.h
    UPD include/generated/timestamp_autogenerated.h
    CHK include/generated/version_autogenerated.h
    CHK include/generated/generic-asm-offsets.h
    CHK include/generated/asm-offsets.h
    CFG u-boot.cfg
    HOSTCC tools/mkenvimage.o
    HOSTCC tools/fit_image.o
    HOSTCC tools/image-host.o
    HOSTCC tools/dumpimage.o
    HOSTCC tools/mkimage.o
    HOSTCC tools/rockchip/boot_merger.o
    HOSTCC tools/rockchip/loaderimage.o
    tools/rockchip/boot_merger.c: In function ‘mergeBoot’:
    tools/rockchip/boot_merger.c:700:43: warning: ‘%s’ directive output may be truncated writing up to 813 bytes into a region of size 5 [-Wformat-truncation=]
    700 | snprintf(buffer, sizeof(buffer), "%s", chip);
    742 | chipType = convertChipType(chip + 2);
    In file included from /usr/include/stdio.h:894,
    from ././include/compiler.h:25,
    from <command-line>:
    /usr/include/x86_64-linux-gnu/bits/stdio2.h:71:10: note: ‘__builtin_snprintf’ output between 1 and 814 bytes into a destination of size 5
    71 | return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,
    72 | __glibc_objsize (__s), __fmt,
    73 | __va_arg_pack ());
    HOSTLD tools/loaderimage
    HOSTLD tools/mkenvimage
    HOSTLD tools/dumpimage
    HOSTLD tools/mkimage
    tools/rockchip/boot_merger.c: In function ‘main’:
    tools/rockchip/boot_merger.c:895:18: warning: array subscript 20 is outside array bounds of ‘char[20]’ [-Warray-bounds]
    895 | str[len] = 0;
    tools/rockchip/boot_merger.c:933:14: note: while referencing ‘name’
    933 | char name[MAX_NAME_LEN];
    HOSTLD tools/boot_merger
    CC cmd/version.o
    CC common/main.o
    LD cmd/built-in.o
    LD common/built-in.o
    CC lib/display_options.o
    LD lib/built-in.o
    LD u-boot
    OBJCOPY u-boot.srec
    OBJCOPY u-boot-nodtb.bin
    SYM u-boot.sym
    make[3]: “arch/arm/dts/rv1106-evb.dtb”已是最新。
    CAT u-boot-dtb.bin
    MKIMAGE u-boot.img
    COPY u-boot.dtb
    MKIMAGE u-boot-dtb.img
    COPY u-boot.bin
    ALIGN u-boot.bin
    COPY spl/u-boot-spl.dtb
    CC spl/common/spl/spl.o
    CC tpl/arch/arm/mach-rockchip/tpl.o
    CC spl/lib/display_options.o
    LD spl/lib/built-in.o
    LD tpl/arch/arm/mach-rockchip/built-in.o
    LD spl/common/spl/built-in.o
    LD spl/u-boot-spl
    LD tpl/u-boot-tpl
    OBJCOPY tpl/u-boot-tpl-nodtb.bin
    COPY tpl/u-boot-tpl.bin
    OBJCOPY spl/u-boot-spl-nodtb.bin
    CAT spl/u-boot-spl-dtb.bin
    COPY spl/u-boot-spl.bin
    CFGCHK u-boot.cfg
    WARN: No tee bin
    pack u-boot.itb okay! Input: /home/vy/luckfox-pico/sysdrv/source/uboot/rkbin/RKTRUST/RV1106TOS.ini
    FIT description: FIT Image with ATF/OP-TEE/U-Boot/MCU
    Created: Mon Aug 19 10:37:24 2024
    Image 0 (uboot)
    Description: U-Boot
    Type: Standalone Program
    Compression: lzma compressed
    Data Size: 172953 Bytes = 168.90 KiB = 0.16 MiB
    Architecture: ARM
    Load Address: 0x00200000
    Entry Point: unavailable
    Hash algo: sha256
    Hash value: a95c90ab13327c88aabb5f9e1378965b1c59d181c8b7a7802fb6d4e996cfb6cf
    Image 1 (fdt)
    Description: U-Boot dtb
    Type: Flat Device Tree
    Compression: uncompressed
    Data Size: 7784 Bytes = 7.60 KiB = 0.01 MiB
    Architecture: ARM
    Hash algo: sha256
    Hash value: 51bba657c35430930647b6cfb31010e5cbd496848b5529f224131ab972111f91
    Default Configuration: 'conf'
    Configuration 0 (conf)
    Description: rv1106-evb
    Kernel: unavailable
    FDT: fdt
    Loadables: uboot
    ********boot_merger ver 1.2********
    Info:Pack loader ok.
    creating new idblock from loader...
    idblock binary saving at rv1106_idblock_v1.10.101.img
    pack loader(SPL) okay! Input: /home/vy/luckfox-pico/sysdrv/source/uboot/rkbin/RKBOOT/RV1106MINIALL.ini
    pack loader with new: spl/u-boot-spl.bin
    Image(no-signed, version=0): uboot.img (FIT with uboot, trust...) is ready
    Image(no-signed): rv1106_idblock_v1.10.101.img (with spl, ddr...) is ready
    pack uboot.img okay! Input: /home/vy/luckfox-pico/sysdrv/source/uboot/rkbin/RKTRUST/RV1106TOS.ini
    Platform RV1106 is build OK, with exist .config
    Mon Aug 19 10:37:25 CST 2024
    '/home/vy/luckfox-pico/sysdrv/source/uboot/u-boot/uboot.img' -> '/home/vy/luckfox-pico/sysdrv/out/image_uclibc_rv1106/uboot.img'
    '/home/vy/luckfox-pico/sysdrv/source/uboot/u-boot/rv1106_idblock_v1.10.101.img' -> '/home/vy/luckfox-pico/sysdrv/out/image_uclibc_rv1106/idblock.img'
    '/home/vy/luckfox-pico/sysdrv/source/uboot/u-boot/rv1106_download_v1.10.106.bin' -> '/home/vy/luckfox-pico/sysdrv/out/image_uclibc_rv1106/download.bin'
    [INSTALL] /home/vy/luckfox-pico/sysdrv/out/image_uclibc_rv1106/idblock.img /home/vy/luckfox-pico/sysdrv/out/image_uclibc_rv1106/uboot.img /home/vy/luckfox-pico/sysdrv/out/image_uclibc_rv1106/download.bin
    TO /home/vy/luckfox-pico/output/image
    ==sysdrv== build kernel
    make -C /home/vy/luckfox-pico/sysdrv/source/kernel ARCH=arm CROSS_COMPILE=arm-rockchip830-linux-uclibcgnueabihf- luckfox_rv1106_linux_defconfig
    make[1]: Entering directory '/home/vy/luckfox-pico/sysdrv/source/kernel'
    LEX scripts/kconfig/lexer.lex.c
    /bin/sh: 1: flex: not found
    make[2]: *** [scripts/Makefile.host:9:scripts/kconfig/lexer.lex.c] 错误 127
    make[1]: *** [Makefile:627: luckfox_rv1106_linux_defconfig] Error 2
    make[1]: Leaving directory '/home/vy/luckfox-pico/sysdrv/source/kernel'
    make: *** [Makefile:429: kernel] Error 2
    make: Leaving directory '/home/vy/luckfox-pico/sysdrv'
    [build.sh:error] Running build_sysdrv failed!
    [build.sh:error] exit code 2 from line 653:
    [build.sh:info] make -C ${SDK_SYSDRV_DIR}
    杨冬青
    email:[email protected]
    Mb.:13818986429
  • 您的SDK环境还缺少对应的库,请参考https://wiki.luckfox.com/zh/Luckfox-Pic ... x-Pico-SDK执行
    sudo apt-get install -y git ssh make gcc gcc-multilib g++-multilib module-assistant expect g++ gawk texinfo libssl-dev bison flex fakeroot cmake unzip gperf autoconf device-tree-compiler libncurses5-dev pkg-config bc python-is-python3 passwd openssl openssh-server openssh-client vim file cpio rsync
  • 谢谢!
    重新安装环境依赖,发现以下三个软件包不能升级:
    python3-update-manager/jammy-updates,jammy-updates 1:22.04.20 all [可从该版本升级:1:22.04.18]
    update-manager-core/jammy-updates,jammy-updates 1:22.04.20 all [可从该版本升级:1:22.04.18]
    请进一步指教一下!
    杨冬青
    Mb.:13818986429
  • SDK 对编译环境的软件包版本要求不大,能够正常进行SDK编译即可,如果需要升级请执行
    sudo apt update
    apt upgrade <Package>
    来升级
  • Hi, the kernel couldn't be compiled, the indication is that there is no space on the device!
    I used 16G SD-card on luckfox-Pico mini B
    I don't know why it's happened?
    /home/vy/luckfox-pico/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin/arm-rockchip830-linux-uclibcgnueabihf-ld.bfd: final link failed: 设备上没有空间
    make[4]: *** [scripts/Makefile.modfinal:79:crypto/ghash-generic.ko] 错误 1
    make[4]: *** 正在等待未完成的任务....
    lib/crypto/libaes.mod.c:24:1: fatal error: error writing to /tmp/cc7B8RDF.s: No space left on device
    MODULE_INFO(depends, "");
    compilation terminated.
    make[4]: *** [scripts/Makefile.modfinal:31:lib/crypto/libaes.mod.o] 错误 1
    lib/crypto/libarc4.mod.c:24:1: fatal error: error writing to /tmp/ccOfVig1.s: No space left on device
    make[4]: *** [scripts/Makefile.modfinal:31:lib/crypto/libarc4.mod.o] 错误 1
    lib/crypto/libsha256.mod.c:24:1: fatal error: error writing to /tmp/cc3ij9bq.s: No space left on device
    make[4]: *** [scripts/Makefile.modfinal:31:lib/crypto/libsha256.mod.o] 错误 1
    net/ipv6/ipv6.mod.c:25:1: fatal error: error writing to /tmp/cc0OtyLK.s: No space left on device
    make[4]: *** [scripts/Makefile.modfinal:31:net/ipv6/ipv6.mod.o] 错误 1
    net/mac80211/mac80211.mod.c:28:1: fatal error: error writing to /tmp/ccFCuQIv.s: No space left on device
    MODULE_INFO(depends, "cfg80211,libarc4");
    make[4]: *** [scripts/Makefile.modfinal:31:net/mac80211/mac80211.mod.o] 错误 1
    net/wireless/cfg80211.mod.c:28:1: fatal error: error writing to /tmp/ccepLF3i.s: No space left on device
    make[4]: *** [scripts/Makefile.modfinal:31:net/wireless/cfg80211.mod.o] 错误 1
    make[3]: *** [scripts/Makefile.modpost:175:__modpost] 错误 2
    make[2]: *** [Makefile:1506:modules] 错误 2
    make[1]: *** [arch/arm/Makefile:372: rv1103g-luckfox-pico-mini-b.img] Error 2
    make: *** [Makefile:430: kernel] Error 2
    [build.sh:error] Running build_kernel failed!
    [build.sh:error] exit code 2 from line 686:
    [build.sh:info] make kernel -C ${SDK_SYSDRV_DIR} KERNEL_CFG=${RK_KERNEL_DEFCONFIG} KERNEL_DTS=${RK_KERNEL_DTS} KERNEL_CFG_FRAGMENT=${RK_KERNEL_DEFCONFIG_FRAGMENT}
    杨冬青
    Mb.:13818986429
  • 这应该就是你的编译环境没有空间了,如果使用的是虚拟机或者WSL可以参考网络上的相关教程进行扩容
  • 您好!
    按照网上教程,需要多大的存储空间呢?16G的SD 还不够吗?
    杨冬青
    Mb.:13818986429
  • SD卡是给Luckfox pico当存储介质使用的,您的问题不是Luckfox Pico的存储介质不够而是编译镜像的机器的存储介质不够,正常至少要有50G空间留给编译使用(不包括系统的其他组件占用的空间),您可以使用df -h(在编译镜像的机器上运行,一般是PC)查看是不是用满了,使用WSL和虚拟机来编译的话存储空间需要设置,直接看电脑的存储空间是看不出来是否用满的
