为什么RNDIS的MAC地址每次插拔USB都会变?
我的PC用的是Ubuntu系统,这样每次OS都会认为这是一个新的设备,之前设置的静态IP的参数每次都要重新来过。能不能固定RNDIS的MAC?
您好 可以参考这个主题viewtopic.php?p=4098&hilit=mac#p4098,将启动的脚本修改为
ifconfig usb0 down
ifconfig usb0 hw ether <Your MAC addr>#更正 原本为 ifconfig usb0 hw ethertg <Your MAC addr>
ifconfig usb0 up
我在里这样改了,没用:
/oem/usr/bin/RkLunch.shCode: Select all
network_init()
ethaddr1=`ifconfig -a | grep "eth.*HWaddr" | awk '{print $5}'`
if [ -f /data/ethaddr.txt ]; then
ethaddr2=`cat /data/ethaddr.txt`
if [ $ethaddr1 == $ethaddr2 ]; then
echo "eth HWaddr cfg ok"
else
ifconfig eth0 down
ifconfig eth0 hw ether $ethaddr2
fi
else
echo $ethaddr1 > /data/ethaddr.txt
fi
ifconfig eth0 up && udhcpc -i eth0
ifconfig usb0 down
ifconfig usb0 hw ethertg BA:B1:44:37:D7:AA
ifconfig usb0 up
我发现了这个issue:
https://github.com/milkv-duo/duo-buildr ... /issues/27
里面人说:
里面人说:
我在那里设置SET_BOOTARGS呢?There is maybe an easier way to do this.
If you set the kernel params something like g_ether.host_addr=00:11:22:33:44:55 g_ether.dev_addr=55:44:33:22:11:00, the ethernet-over-usb driver (CONFIG_USB_ETH) will not generate random MACs for the host and the device.
For the buildroot image, this would need to be set in SET_BOOTARGS in various places.
很抱歉,前面提供的参考有误,设置MAC地址的命令应该为
usb的初始化在执行RkLunch.sh之后,所以要添加脚本的位置应该在 /etc/init.d/S99usb0config 的 usb0_config 函数下
如果需要修改BOOTARG的话直接修改设备树中/choose节点的bootargs,放在luckfox-pico的dts对应的dtsi中
ifconfig usb0 hw ether <Your MAC Address>
usb0_config() {
if [ "$(cat /proc/device-tree/usbdrd/usb@ffb00000/dr_mode)" == "peripheral" ]; then
################# Add Here ####################
ifconfig usb0 down
ifconfig usb0 hw ether 2A:EE:82:4A:7C:0C
ifconfig usb0 up
sleep 0.5
##################### END ######################
current_ip=$(ifconfig usb0 | grep -o 'inet addr:[^ ]*' | awk -F ':' '{print $2}')
echo "current_ip = $current_ip"
echo "TARGET_IP = $TARGET_IP"
while [[ "$current_ip" != "$TARGET_IP" && $retries -lt $MAX_RETRIES ]]; do
sleep .5
echo "luckfox : set usb0 ip"
ifconfig usb0 "$TARGET_IP"
echo $current_ip
retries=$((retries + 1))
done
if [[ "$current_ip" != "$TARGET_IP" ]]; then
echo "usb0 config error"
else
echo "usb0 config success"
fi
else
echo "usb0 is using host mode"
fi
我按照这个方法改了MAC还是无法固定。然后尝试改设备树文件加入 :
依旧是一点用也没。。。
g_ether.dev_addr=12:34:56:78:9a:bc g_ether.host_addr=12:34:56:78:9a:bdCode: Select all
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
* Copyright (c) 2022 Rockchip Electronics Co., Ltd.
#include "rv1106-amp.dtsi"
chosen {
bootargs = "earlycon=uart8250,mmio32,0xff4c0000 console=ttyFIQ0 root=/dev/mmcblk1p7 rootwait snd_soc_core.prealloc_buffer_size_kbytes=16 coherent_pool=0 g_ether.dev_addr=12:34:56:78:9a:bc g_ether.host_addr=12:34:56:78:9a:bd";
Crocodile wrote: ↑2024-11-25 6:01 很抱歉,前面提供的参考有误,设置MAC地址的命令应该为usb的初始化在执行RkLunch.sh之后,所以要添加脚本的位置应该在 /etc/init.d/S99usb0config 的 usb0_config 函数下Code: Select all
ifconfig usb0 hw ether <Your MAC Address>如果需要修改BOOTARG的话直接修改设备树中/choose节点的bootargs,放在luckfox-pico的dts对应的dtsi中Code: Select all
usb0_config() { if [ "$(cat /proc/device-tree/usbdrd/usb@ffb00000/dr_mode)" == "peripheral" ]; then ################################################ ################# Add Here #################### ################################################ ifconfig usb0 down ifconfig usb0 hw ether 2A:EE:82:4A:7C:0C ifconfig usb0 up sleep 0.5 ################################################ ##################### END ###################### ################################################ current_ip=$(ifconfig usb0 | grep -o 'inet addr:[^ ]*' | awk -F ':' '{print $2}') echo "current_ip = $current_ip" echo "TARGET_IP = $TARGET_IP" while [[ "$current_ip" != "$TARGET_IP" && $retries -lt $MAX_RETRIES ]]; do sleep .5 echo "luckfox : set usb0 ip" ifconfig usb0 "$TARGET_IP" current_ip=$(ifconfig usb0 | grep -o 'inet addr:[^ ]*' | awk -F ':' '{print $2}') echo $current_ip retries=$((retries + 1)) done if [[ "$current_ip" != "$TARGET_IP" ]]; then echo "usb0 config error" else echo "usb0 config success" fi else echo "usb0 is using host mode" fi }
使用该脚本的方法实测是没有问题的,现在修改加入延时确保不与IP设置冲突,您可以再次尝试一下,bootarg直接添加内容如果内核无法解析会传入用户空间,不确定有没有应用来接收处理添加的内容也是无法生效的
Crocodile wrote: ↑2024-11-29 1:30Crocodile wrote: ↑2024-11-25 6:01 很抱歉,前面提供的参考有误,设置MAC地址的命令应该为usb的初始化在执行RkLunch.sh之后,所以要添加脚本的位置应该在 /etc/init.d/S99usb0config 的 usb0_config 函数下Code: Select all
你好 我想请问一下 我想2个板子插一台电脑同时使用,我修改了其中一个板子的S99usb0config文件的ip,修改为了172.32.0.99,还有一块板子是默认ip,我使用的时候还是只能连接一个板子,想同时连接2块板子除了修改ip,还需要修改什么呢。
两个设备查到电脑上正常会出现两个RNDIS设备,电脑需要修改两个RNDIS设备不能占用同个IP(比如 172.32.0.1 和 172.32.0.2),设备也不能使用同个IP(比如172.32.0.92和172.32.0.93),建议不同设备使用不同的网段(比如板A IP设置为 172.32.0.93,电脑对应的RNDIS设置为 172.32.0.100,板B IP设置为 172.32.1.93,电脑对应的RNDIS设置为 172.32.1.100)
Hi
I faced the same issue. I am working with Ultra on Ubuntu 24.04. Here is my solution from the host side without setting a static MAC (see PDF attached for details):
After reconnect, the interface will always be `usbnet0` with IP `172.32.0.100`.
# 1. Create a udev rule
echo 'SUBSYSTEM=="net", ACTION=="add", ATTRS{idVendor}=="2207", ATTRS{idProduct}=="0019", NAME="usbnet0"' \
| sudo tee /etc/udev/rules.d/70-luckfox.rules
sudo udevadm control --reload-rules && sudo udevadm trigger
# 2. Assign a permanent static IP to the *host*
# Use an address in the same subnet (172.32.0.x/24),
# but different from the board’s default IP (172.32.0.93).
nmcli con add type ethernet ifname usbnet0 con-name usbnet0 \
ipv4.addresses 172.32.0.100/24 ipv4.method manual
