Debugging the Cortex-M0 Core with openocd
  • Hello, this issue is beyond the scope of technical support and we don't have JTAG devices available to verify if the settings are successful. I can only offer some basic suggestions and I won't participate in further discussions.
    Based on your description, GRF_SOC_CON0 is set with 5:4 as 10, the default JTAGM0 configuration is SDMMC, and JTAGM1 is used for the MCU. The related pin re-mapping configuration is also fine. I think it might be that the interrupt or clock resources of JTAG are occupied by the AP core, which are typically used by the AP core's fiqdebug.
    The AMP configuration we provide defaults to loading the MCU's firmware at 0xfff84000. There is also a possibility that a firmware loading address needs to be allocated to the MCU or the firmware needs to be loaded in order to start JTAG debugging.
    grf_con_mcu_dbgen does not provide a base address. It might be for setting the debug serial port. I think the configuration of this register should not affect the JTAG connection.
  • Crocodile wrote: 2025-07-26 3:42 Hello, this issue is beyond the scope of technical support and we don't have JTAG devices available to verify if the settings are successful. I can only offer some basic suggestions and I won't participate in further discussions.
    The "Rockchip_Developer_Guide_AMP_EN.pdf" guide links to a non-assailable portion of documentation ?
    https://github.com/ArmSoM/rk3506-rkr4.2 ... AMP_EN.pdf
    Section 15.2 Debugging with OpenOCD - JTAG & SWD Connection Development and Debugging
    pg 109
    Do you have access to it ?
  • Due to the absence of JTAG & SWD devices, we have not conducted any tests for this function.
  • Hello. I had a same problem and found some workaround to debug M0 core with JTAG debugger.
    As you stated, I was also unable to find any more details about `grf_con_mcu_dbgen` register bit, which seems essential to enable JTAG debug access on M0 core.
    So I looked through u-boot code from SDK and found the below parts inside u-boot/arch/arm/mach-rockchip/rk3506/rk3506.c
    //inside int arch_cpu_init(void)
    	 * Set mcu jtag clock un-gate.
    	 * Configure when in use.
    	//writel(0x00220000, 0xff960000);
    Once I uncommented writel(0x00220000, 0xff960000); this line, rebuild the SDK and flash the updated firmware, now M0 core is accessible through JTAG debugger.
    Again, I couldn't find any details about the register 0xff960000, except the fact that it is called SGRF_PMU.
    Anyway there are two ways to access SWD pins of M0 core.
    1. If you want to use UART0 pins as SWD pins, then run the below register write codes as you did before.
    devmem 0xFF288000 w 0x00300020		//sgrf_jtag_sel (port M1 to MCU)
    devmem 0xFF950014 w 0x33002200		//change UART0 pins to JTAG_M1 pins
    2. Or, if you want to keep UART0 and would like extra pins for M0 core debugging, you can use micro-SD breakout board (something like below image).
    Then connect
    SDMMC_D2(GPIO3_A4) to TCK, and
    SDMMC_D3(GPIO3_A5) to TMS
    Now run below register write codes
    devmem 0xFF288000 w 0x00300010		//sgrf_jtag_sel (port M0 to MCU)
    devmem 0xFF4D8064 w 0x00330022		//change micro SD pins to JTAG_M0 pins
    I tested it on Ubuntu22.04 JLinkExe
    yjkimmy:~$ JLinkExe
    SEGGER J-Link Commander V8.86 (Compiled Nov 12 2025 12:28:56)
    DLL version V8.86, compiled Nov 12 2025 12:27:53
    Connecting to J-Link via USB...O.K.
    Firmware: J-Link Pro V4 V11 PLUS Oct compiled 1 2024 13:26:26
    Hardware version: V11.00
    J-Link uptime (since boot): 0d 00h 04m 03s
    License(s): FlashBP, GDB, JFlash, FlashDL, RDI
    USB speed mode: High speed (480 MBit/s)
    IP-Addr: 255.255.255.255 (DHCP)
    VTref=3.322V
    Type "connect" to establish a target connection, '?' for help
    J-Link>connect
    Please specify device / core. <Default>: CORTEX-M0
    Type '?' for selection dialog
    Device>
    Please specify target interface:
      J) JTAG (Default)
      S) SWD
      T) cJTAG
    TIF>S
    Specify target interface speed [kHz]. <Default>: 4000 kHz
    Speed>
    Device "CORTEX-M0" selected.
    Connecting to target via SWD
    Found SW-DP with ID 0x0BB11477
    DPIDR: 0x0BB11477
    CoreSight SoC-400 or earlier
    Scanning AP map to find all available APs
    AP[1]: Stopped AP scan as end of AP map has been reached
    AP[0]: AHB-AP (IDR: 0x04770021, ADDR: 0x00000000)
    Iterating through AP map to find AHB-AP to use
    AP[0]: Core found
    AP[0]: AHB-AP ROM base: 0xE00FF000
    CPUID register: 0x410CC200. Implementer code: 0x41 (ARM)
    Found Cortex-M0 r0p0, Little endian.
    FPUnit: 4 code (BP) slots and 0 literal slots
    CoreSight components:
    ROMTbl[0] @ E00FF000
    [0][0]: E000E000 CID B105E00D PID 000BB008 SCS
    [0][1]: E0001000 CID B105E00D PID 000BB00A DWT
    [0][2]: E0002000 CID B105E00D PID 000BB00B FPB
    Memory zones:
      Zone: "Default" Description: Default access mode
    Cortex-M0 identified.
    J-Link>
