App 0.0.4
System 0.1.2
Sometimes, the mouse pointer disappears from virtual screen and I managed to use it again only after issuing a reboot command on the terminal.
In that matter, I preferred the previous version which had no this problem.
In addition, the screen is a bit blurry. I am using it on screens 1900x1200 and and it is blurry both on fullscreen, both on windowed mode. When fullscreen, there is a frame around it. I am trying to mirror a screen with the same resolution.
Disappearing mouse pointer and blurry screen
Hello, regarding the USB device issue, we are still optimizing it. Turning off the "Automatically mount system_info.img" option in Virtual Media will improve the situation a bit.
Settings -> Advanced -> Troubleshooting Mode -> USB Gadget Reinitialize can reinitialize the USB without rebooting, which can solve most connection problems.
Since the encoding stage is fixed at 1920x1080, if the image is not 1920x1080, there will be black borders.
The blurring issue, we will try to determine if there is still room for optimization in the encoding process.
