RKIPC configuration
  • I have not tested or used any FEC-related features, but I think this might be related to the kernel configuration. Please refer to the appendix document (currently only a Chinese version is available; you can use translation software to read it).
  • Thank you for the prompt response!
    Could you provide a link to the "appendix document" or its full title?
  • This is the FEC-related documentation.
    Downloaded 279 times
  • Turns out, the FEC works fine after one sets this in rkisp.ini:
    [isp.0.enhancement]
    distortion_correction = FEC
    distortion correction is normally a boolean. However, 'FEC' is a 3rd value reserved for use with the RV1126B. You don't get per stream selection. FEC is on for all streams or off for all.
