That was surely an issue too. But after enabling that it still did not work so I checked dmesg:
cfg80211: failed to load regulatory.db
pointed me to the fact that I was also missing wireless regdb.
Still no success, so i also tried unplugging the wifi stick and plugging it in again. dmesg reports on an USB event, but still no success.
[root@luckfox root]# dmesg
[ 0.192771] Goodix-TS 3-0014: supply AVDD28 not found, using dummy regulator
[ 0.192944] Goodix-TS 3-0014: supply VDDIO not found, using dummy regulator
[ 0.193228] Goodix-TS 3-0014: i2c test failed attempt 1: -6
[ 0.226939] Goodix-TS 3-0014: i2c test failed attempt 2: -6
[ 0.266782] Goodix-TS 3-0014: I2C communication failure: -6
[ 0.269326] usbcore: registered new interface driver uvcvideo
[ 0.269350] USB Video Class driver (1.1.1)
[ 0.269990] Bluetooth: HCI UART driver ver 2.3
[ 0.270009] Bluetooth: HCI UART protocol H4 registered
[ 0.270181] cpu cpu0: leakage=18
[ 0.270983] Synopsys Designware Multimedia Card Interface Driver
[ 0.271889] dtbocfg: 0.1.0
[ 0.271931] dtbocfg: OK
[ 0.273080] dwmmc_rockchip ffa90000.mmc: IDMAC supports 32-bit address mode.
[ 0.273125] dwmmc_rockchip ffa90000.mmc: Using internal DMA controller.
[ 0.273143] dwmmc_rockchip ffa90000.mmc: Version ID is 270a
[ 0.273181] dwmmc_rockchip ffa90000.mmc: DW MMC controller at irq 55,32 bit host data width,256 deep fifo
[ 0.273292] mmc_host mmc0: card is non-removable.
[ 0.273539] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.274110] dwmmc_rockchip ffaa0000.mmc: No normal pinctrl state
[ 0.274132] dwmmc_rockchip ffaa0000.mmc: No idle pinctrl state
[ 0.274267] dwmmc_rockchip ffaa0000.mmc: IDMAC supports 32-bit address mode.
[ 0.274302] dwmmc_rockchip ffaa0000.mmc: Using internal DMA controller.
[ 0.274319] dwmmc_rockchip ffaa0000.mmc: Version ID is 270a
[ 0.274359] dwmmc_rockchip ffaa0000.mmc: DW MMC controller at irq 56,32 bit host data width,256 deep fifo
[ 0.274457] dwmmc_rockchip ffaa0000.mmc: allocated mmc-pwrseq
[ 0.274474] mmc_host mmc1: card is non-removable.
[ 0.275457] usbcore: registered new interface driver snd-usb-audio
[ 0.276073] rv1106-acodec ff480000.acodec: current soc_id: rv1106
[ 0.276158] rv1106-acodec ff480000.acodec: Use pa_ctl_gpio and pa_ctl_delay_ms: 0
[ 0.277820] NET: Registered protocol family 17
[ 0.278087] Bluetooth: RFCOMM TTY layer initialized
[ 0.278115] Bluetooth: RFCOMM socket layer initialized
[ 0.278147] Bluetooth: RFCOMM ver 1.11
[ 0.278202] [BT_RFKILL]: Enter rfkill_rk_init
[ 0.278211] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 0.278738] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 5.
[ 0.278781] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 2.
[ 0.278801] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 34.
[ 0.278816] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 0.278864] [BT_RFKILL]: Failed to get bt_default_wake_host gpio.
[ 0.278908] rfkill_bt: probe of wireless-bluetooth failed with error -1
[ 0.278985] Key type dns_resolver registered
[ 0.279886] Loading compiled-in X.509 certificates
[ 0.295075] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.308610] rockchip-drm display-subsystem: bound ff990000.vop (ops 0xb043ac84)
[ 0.308690] rockchip-drm display-subsystem: bound ff000000.syscon:rgb (ops 0xb043b7e4)
[ 0.308940] rockchip-drm display-subsystem: failed to parse resources for logo display
[ 0.310606] rockchip-vop ff990000.vop: [drm:vop_crtc_atomic_enable] Update mode to 720x720p49, type: 17
[ 0.331405] mmc_host mmc0: Bus speed (slot 0) = 49500000Hz (slot req 52000000Hz, actual 49500000HZ div = 0)
[ 0.332391] mmc0: new high speed MMC card at address 0001
[ 0.332848] mmcblk0: mmc0:0001 AT2S38 7.23 GiB
[ 0.332924] mmcblk0boot0: mmc0:0001 AT2S38 partition 1 4.00 MiB
[ 0.333000] mmcblk0boot1: mmc0:0001 AT2S38 partition 2 4.00 MiB
[ 0.333180] mmcblk0rpmb: mmc0:0001 AT2S38 partition 3 4.00 MiB, chardev (247:0)
[ 0.333795] mmcblk0: p1(env) p2(idblock) p3(uboot) p4(boot) p5(oem) p6(userdata) p7(rootfs)
[ 0.335890] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 0.357383] Console: switching to colour frame buffer device 90x45
[ 0.373634] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[ 0.374352] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[ 0.374866] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 0.389972] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 0.436843] mmc_host mmc1: Bus speed (slot 0) = 187500Hz (slot req 100000Hz, actual 93750HZ div = 1)
[ 0.459716] ALSA device list:
[ 0.459743] #0: rv1106-acodec
[ 0.476883] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 0.480147] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 0.480219] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[ 0.484738] devtmpfs: mounted
[ 0.484947] Freeing unused kernel memory: 204K
[ 0.484957] Kernel memory protection not selected by kernel config.
[ 0.484984] Run /sbin/init as init process
[ 0.484991] with arguments:
[ 0.484995] /sbin/init
[ 0.484998] with environment:
[ 0.485002] HOME=/
[ 0.485006] TERM=linux
[ 0.485010] user_debug=31
[ 0.485012] storagemedia=emmc
[ 0.485017] earlycon=uart8250,mmio32,0xff4c0000
[ 0.489207] process '/bin/busybox' started with executable stack
[ 0.552033] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[ 0.760489] udevd[99]: starting version 3.2.7
[ 0.764977] udevd[99]: specified group 'input' unknown
[ 0.765943] udevd[99]: specified group 'kvm' unknown
[ 0.787871] udevd[100]: starting eudev-3.2.7
[ 1.844175] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 1.844227] ext4 filesystem being mounted at /userdata supports timestamps until 2038 (0x7fffffff)
[ 1.998424] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 2.180289] rk_dvbm ffa70000.rkdvbm: probe start
[ 2.180327] rk_dvbm ffa70000.rkdvbm: dvbm ctx 2b0e8858
[ 2.180629] rk_dvbm ffa70000.rkdvbm: probe success
[ 2.218323] sc3336 4-0030: driver version: 00.01.01
[ 2.218426] sc3336 4-0030: Failed to get pwdn-gpios
[ 2.218441] sc3336 4-0030: could not get default pinstate
[ 2.218451] sc3336 4-0030: could not get sleep pinstate
[ 2.218474] sc3336 4-0030: supply avdd not found, using dummy regulator
[ 2.218683] sc3336 4-0030: supply dovdd not found, using dummy regulator
[ 2.218757] sc3336 4-0030: supply dvdd not found, using dummy regulator
[ 2.228076] sc3336 4-0030: Unexpected sensor id(000000), ret(-5)
[ 2.242353] mis5001 4-0031: driver version: 00.01.02
[ 2.242458] mis5001 4-0031: Failed to get pwdn-gpios
[ 2.242473] mis5001 4-0031: could not get default pinstate
[ 2.242482] mis5001 4-0031: could not get sleep pinstate
[ 2.242507] mis5001 4-0031: supply avdd not found, using dummy regulator
[ 2.242725] mis5001 4-0031: supply dovdd not found, using dummy regulator
[ 2.242789] mis5001 4-0031: supply dvdd not found, using dummy regulator
[ 2.253089] mis5001 4-0031: Unexpected sensor id(000000), ret(-5)
[ 2.307863] rkcifhw ffa10000.rkcif: no iommu attached, using non-iommu buffers
[ 2.307887] rkcifhw ffa10000.rkcif: No reserved memory region assign to CIF
[ 2.308317] rkcif rkcif-mipi-lvds: rkcif driver version: v00.02.00
[ 2.308430] rkcif rkcif-mipi-lvds: attach to cif hw node
[ 2.308444] rkcif rkcif-mipi-lvds: failed to get dphy hw node
[ 2.308454] rkcif rkcif-mipi-lvds: rkcif wait line 0
[ 2.308465] rkcif rkcif-mipi-lvds: rkcif fastboot reserve bufs num 3
[ 2.308477] : terminal subdev does not exist
[ 2.308487] : terminal subdev does not exist
[ 2.308496] : terminal subdev does not exist
[ 2.308503] : terminal subdev does not exist
[ 2.308513] : get_remote_sensor: video pad[0] is null
[ 2.308523] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 2.308534] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 2.308542] : get_remote_sensor: video pad[0] is null
[ 2.308549] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 2.308559] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 2.308566] : get_remote_sensor: video pad[0] is null
[ 2.308572] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 2.308581] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 2.308589] : get_remote_sensor: video pad[0] is null
[ 2.308596] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 2.308604] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 2.324082] rkcif rkcif-mipi-lvds: No memory-region-thunderboot specified
[ 2.325283] rockchip-mipi-csi2-hw ffa20000.mipi-csi2-hw: enter mipi csi2 hw probe!
[ 2.325443] rockchip-mipi-csi2-hw ffa20000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[ 2.325568] rockchip-mipi-csi2-hw ffa30000.mipi-csi2-hw: enter mipi csi2 hw probe!
[ 2.325683] rockchip-mipi-csi2-hw ffa30000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[ 2.326125] rockchip-mipi-csi2 mipi0-csi2: attach to csi2 hw node
[ 2.326190] rkcif rkcif-mipi-lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 2.326207] rockchip-mipi-csi2: Async registered subdev
[ 2.326216] rockchip-mipi-csi2: probe success, v4l2_dev:rkcif-mipi-lvds!
[ 2.365953] rkisp_hw ffa00000.rkisp: is_thunderboot: 0
[ 2.365981] rkisp_hw ffa00000.rkisp: Missing rockchip,grf property
[ 2.366025] rkisp_hw ffa00000.rkisp: max input:0x0@0fps
[ 2.366190] rkisp_hw ffa00000.rkisp: get sram size:253952
[ 2.366206] rkisp_hw ffa00000.rkisp: no iommu attached, using non-iommu buffers
[ 2.366216] rkisp_hw ffa00000.rkisp: No reserved memory region. default cma area!
[ 2.366577] rkisp rkisp-vir0: rkisp driver version: v02.05.00
[ 2.366742] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 2.368441] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 2.404364] rockchip-csi2-dphy-hw ff3e8000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 2.420890] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 2.837572] rkcif rkcif-mipi-lvds: clear unready subdev num: 2
[ 2.838591] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 2.838613] rkcif-mipi-lvds: Async subdev notifier completed
[ 2.838637] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 2.838646] rkcif-mipi-lvds: There is not terminal subdev, not synchronized with ISP
[ 2.838903] rkisp rkisp-vir0: clear unready subdev num: 1
[ 2.839118] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 2.839131] rkcif-mipi-lvds: There is not terminal subdev, not synchronized with ISP
[ 2.839661] rkisp-vir0: Async subdev notifier completed
[ 2.856929] rga: rga2, irq = 40, match scheduler
[ 2.860372] rga: rga2 hardware loaded successfully, hw_version:3.3.87975.
[ 2.860398] rga: rga2 probe successfully
[ 2.860678] rga_iommu: IOMMU binding successfully, default mapping core[0x4]
[ 2.861700] rga: Module initialized. v1.3.1
[ 2.888934] mpp_vcodec: loading out-of-tree module taints kernel.
[ 2.904981] mpp_vcodec: init new
[ 2.905129] mpp_service mpp-srv: 424abb9b author: Yandong Lin 2024-04-29 [mpp_enc]: fix wrap enc sw timeout when resolution switch
[ 2.905144] mpp_service mpp-srv: probe start
[ 2.909402] mpp_rkvenc_540c ffa50000.rkvenc: probing start
[ 2.909663] mpp_rkvenc_540c ffa50000.rkvenc: probing finish
[ 2.910113] mpp_vepu_pp ffa60000.rkvenc-pp: probe device
[ 2.910212] mpp_vepu_pp ffa60000.rkvenc-pp: shared_rst_a_pp is not found!
[ 2.910224] vepu_pp_init:526: No aclk reset resource define
[ 2.910234] mpp_vepu_pp ffa60000.rkvenc-pp: shared_rst_h_pp is not found!
[ 2.910240] vepu_pp_init:529: No hclk reset resource define
[ 2.912613] mpp_vepu_pp ffa60000.rkvenc-pp: probing finish
[ 2.912881] mpp_service mpp-srv: probe success
[ 2.942756] RKNPU ff660000.npu: RKNPU: rknpu iommu device-tree entry not found!, using non-iommu mode
[ 2.943130] RKNPU ff660000.npu: RKNPU: Initialized RKNPU driver: v0.9.2 for 20230825
[ 2.943216] RKNPU ff660000.npu: dev_pm_opp_set_regulators: no regulator (rknpu) found: -19
[ 2.997757] rockit_load start
[ 3.011278] rockit_load end
[ 3.024860] rve: rve_irq, irq = 57, match scheduler
[ 3.025081] rve: Driver loaded successfully rve[2] ver:[2021]58.1a
[ 3.025099] rve: probe successfully
[ 3.027614] rve: Module initialized. v1.0.6
[ 3.168138] pwm-backlight backlight: supply power not found, using dummy regulator
[ 3.195950] udevd[315]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video0': No such file or directory
[ 3.219847] udevd[318]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video1': No such file or directory
[ 3.222598] udevd[319]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video2': No such file or directory
[ 3.223675] udevd[320]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video3': No such file or directory
[ 3.245404] udevd[323]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video4': No such file or directory
[ 3.246504] udevd[324]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video5': No such file or directory
[ 3.248015] udevd[325]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video6': No such file or directory
[ 3.474490] rk_gmac-dwmac ffa80000.ethernet eth0: PHY [stmmac-0:02] driver [RK630 PHY] (irq=POLL)
[ 3.474828] dwmac4: Master AXI performs any burst length
[ 3.474857] rk_gmac-dwmac ffa80000.ethernet eth0: No Safety Features support found
[ 3.474878] rk_gmac-dwmac ffa80000.ethernet eth0: PTP not supported by HW
[ 3.475169] rk_gmac-dwmac ffa80000.ethernet eth0: configuring for phy/rmii link mode
[ 3.626895] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.674262] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.732136] libaes: exports duplicate symbol aes_decrypt (owned by kernel)
[ 3.732535] libaes: exports duplicate symbol aes_decrypt (owned by kernel)
[ 3.763591] aicbsp_init
[ 3.763620] RELEASE_DATE:2025_0410_b99ca8b6
[ 3.763630] aicbsp_resv_mem_init
[ 4.020293] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[ 4.020323] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[ 4.020332] aicbsp: aicbsp_platform_power_on
[ 5.527581] rk_gmac-dwmac ffa80000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 6.101919] aicbsp: aicbsp_set_subsys, fail to set AIC_WIFI power state to 1
[ 6.124591] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[ 6.124615] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[ 6.124623] aicbsp: aicbsp_platform_power_on
[ 6.551878] file system registered
[ 6.572534] using random self ethernet address
[ 6.572560] using random host ethernet address
[ 6.588175] Mass Storage Function, version: 2009/09/11
[ 6.588202] LUN: removable file: (no medium)
[ 6.692046] read descriptors
[ 6.692119] read strings
[ 8.182028] aicbsp: aicbsp_set_subsys, fail to set AIC_WIFI power state to 1
[ 10.224888] aic_bluetooth_mod_init
[ 10.225251] -->rfkill_bluetooth_init
[ 10.225380] <--rfkill_bluetooth_init
[ 149.403533] usb 1-1: USB disconnect, device number 2
[ 152.046799] usb 1-1: new high-speed USB device number 3 using xhci-hcd
[root@luckfox root]# lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 003: ID 148f:5572
Bus 002 Device 001: ID 1d6b:0003
