Pico Pi A W RV1106G3: Photo capture in 200ms after PIR trigger? (12V 1A supply)
  • Hi,
    Your question falls under the category of secondary development. It requires independent design and verification. We have not conducted any relevant tests.
    From what we can share:
    1 Achieving full boot + MIS5001 initialization + first frame capture within 200 ms is very challenging. It would require a dedicated fast-boot image with optimized camera initialization. Even then, it is marginal and not guaranteed.
    2 In such a short time window, the ISP (e.g., AE) may not be fully initialized, so the captured frame could be very dark or unusable.
    3 A more practical approach is to keep the camera pipeline running continuously, and use the PIR trigger only to save a frame. In this case, capturing and storing an image within 200 ms is achievable.
  • Currently, we are using AOV (Always-On Vision) mode, which gives us a boot time of about 6–8 seconds.
    In sleep mode, the board consumes approximately 0.3 W.
    Our target is to reduce the sleep-mode power consumption to below 0.2 W.
    Any suggestions or recommended configurations to achieve lower power consumption would be appreciated.
  • We have no experience or development plans regarding AOV and suspend-wakeup functions. Issues related to these areas are not covered by our technical support, as we have clearly informed you in previous topics
