Unable to achieve 1080p 30FPS on Luckfox Pico Zero (IMX415) using rkipc.ini – stuck at ~12 FPS
  • The resolution set in rkipc is only the scaled resolution; the image actually captured from the sensor remains 3840x2160. The maximum frame rate of the IMX415 on RV1106 is around 4K @ 15 FPS, which is limited by the CSI PHY bandwidth. Therefore, modifying the rkipc.ini is ineffective.
    You need to change the output resolution directly in the driver to 1920x1080. Below is a configuration gathered from online sources. We have not tested it, so you need to verify its usability yourself.
     * Xclk 37.125Mhz
    static __maybe_unused const struct regval imx415_linear_10bit_1920x1080_891M_regs[] = {
    IMX415-AAQR Window cropping 1920x1080 CSI-2_4lane 37.125MHz AD:10bit Output:10bit 891Mbps Master Mode 60.012fps Integration Time 14.442ms
    Tool ver : Ver9.0
    	{0x3008, 0x7F},  // BCWAIT_TIME[9:0]
    	{0x300A, 0x5B},  // CPWAIT_TIME[9:0]
    	{0x3020, 0x01},  // HADD .
    	{0x3021, 0x01},  // VADD .
    	{0x3022, 0x01},  // ADDMODE[1:0] .
    	{0x3024, 0xCA},  // VMAX[19:0]
    	{0x3025, 0x08},
    	{0x3028, 0x26},  // HMAX[15:0]
    	{0x3029, 0x02},
    	{0x3031, 0x00},  // ADBIT[1:0]
    	{0x3033, 0x04},  // SYS_MODE[3:0] .
    	{0x3050, 0x08},  // SHR0[19:0] .
    	{0x30C1, 0x00},  // XVS_DRV[1:0]
    	{0x30D9, 0x02},  // DIG_CLP_VSTART[4:0]
    	{0x30DA, 0x01},  // DIG_CLP_VNUM[1:0]
    	{0x3116, 0x24},  // INCKSEL2[7:0]
    	{0x3118, 0xC0},  // INCKSEL3[10:0]
    	{0x311A, 0xE0},  // INCKSEL4[10:0]
    	{0x311E, 0x24},  // INCKSEL5[7:0]
    	{0x32D4, 0x21},  // -
    	{0x32EC, 0xA1},  // -
    	{0x344C, 0x2B},  // -
    	{0x344D, 0x01},  // -
    	{0x344E, 0xED},  // -
    	{0x344F, 0x01},  // -
    	{0x3450, 0xF6},  // -
    	{0x3451, 0x02},  // -
    	{0x3452, 0x7F},  // -
    	{0x3453, 0x03},  // -
    	{0x358A, 0x04},  // -
    	{0x35A1, 0x02},  // -
    	{0x35EC, 0x27},  // -
    	{0x35EE, 0x8D},  // -
    	{0x35F0, 0x8D},  // -
    	{0x35F2, 0x29},  // -
    	{0x36BC, 0x0C},  // -
    	{0x36CC, 0x53},  // -
    	{0x36CD, 0x00},  // -
    	{0x36CE, 0x3C},  // -
    	{0x36D0, 0x8C},  // -
    	{0x36D1, 0x00},  // -
    	{0x36D2, 0x71},  // -
    	{0x36D4, 0x3C},  // -
    	{0x36D6, 0x53},  // -
    	{0x36D7, 0x00},  // -
    	{0x36D8, 0x71},  // -
    	{0x36DA, 0x8C},  // -
    	{0x36DB, 0x00},  // -
    	{0x3701, 0x00},  // ADBIT1[7:0]
    	{0x3720, 0x00},  // -
    	{0x3724, 0x02},  // -
    	{0x3726, 0x02},  // -
    	{0x3732, 0x02},  // -
    	{0x3734, 0x03},  // -
    	{0x3736, 0x03},  // -
    	{0x3742, 0x03},  // -
    	{0x3862, 0xE0},  // -
    	{0x38CC, 0x30},  // -
    	{0x38CD, 0x2F},  // -
    	{0x395C, 0x0C},  // -
    	{0x39A4, 0x07},  // -
    	{0x39A8, 0x32},  // -
    	{0x39AA, 0x32},  // -
    	{0x39AC, 0x32},  // -
    	{0x39AE, 0x32},  // -
    	{0x39B0, 0x32},  // -
    	{0x39B2, 0x2F},  // -
    	{0x39B4, 0x2D},  // -
    	{0x39B6, 0x28},  // -
    	{0x39B8, 0x30},  // -
    	{0x39BA, 0x30},  // -
    	{0x39BC, 0x30},  // -
    	{0x39BE, 0x30},  // -
    	{0x39C0, 0x30},  // -
    	{0x39C2, 0x2E},  // -
    	{0x39C4, 0x2B},  // -
    	{0x39C6, 0x25},  // -
    	{0x3A42, 0xD1},  // -
    	{0x3A4C, 0x77},  // -
    	{0x3AE0, 0x02},  // -
    	{0x3AEC, 0x0C},  // -
    	{0x3B00, 0x2E},  // -
    	{0x3B06, 0x29},  // -
    	{0x3B98, 0x25},  // -
    	{0x3B99, 0x21},  // -
    	{0x3B9B, 0x13},  // -
    	{0x3B9C, 0x13},  // -
    	{0x3B9D, 0x13},  // -
    	{0x3B9E, 0x13},  // -
    	{0x3BA1, 0x00},  // -
    	{0x3BA2, 0x06},  // -
    	{0x3BA3, 0x0B},  // -
    	{0x3BA4, 0x10},  // -
    	{0x3BA5, 0x14},  // -
    	{0x3BA6, 0x18},  // -
    	{0x3BA7, 0x1A},  // -
    	{0x3BA8, 0x1A},  // -
    	{0x3BA9, 0x1A},  // -
    	{0x3BAC, 0xED},  // -
    	{0x3BAD, 0x01},  // -
    	{0x3BAE, 0xF6},  // -
    	{0x3BAF, 0x02},  // -
    	{0x3BB0, 0xA2},  // -
    	{0x3BB1, 0x03},  // -
    	{0x3BB2, 0xE0},  // -
    	{0x3BB3, 0x03},  // -
    	{0x3BB4, 0xE0},  // -
    	{0x3BB5, 0x03},  // -
    	{0x3BB6, 0xE0},  // -
    	{0x3BB7, 0x03},  // -
    	{0x3BB8, 0xE0},  // -
    	{0x3BBA, 0xE0},  // -
    	{0x3BBC, 0xDA},  // -
    	{0x3BBE, 0x88},  // -
    	{0x3BC0, 0x44},  // -
    	{0x3BC2, 0x7B},  // -
    	{0x3BC4, 0xA2},  // -
    	{0x3BC8, 0xBD},  // -
    	{0x3BCA, 0xBD},  // -
    	{0x4004, 0x48},  // TXCLKESC_FREQ[15:0]
    	{0x4005, 0x09},  //
    	{0x400C, 0x00},  // INCKSEL6
    	{0x4018, 0x7F},  // TCLKPOST[15:0]
    	{0x401A, 0x37},  // TCLKPREPARE[15:0]
    	{0x401C, 0x37},  // TCLKTRAIL[15:0]
    	{0x401E, 0xF7},  // TCLKZERO[15:0]
    	{0x401F, 0x00},  //
    	{0x4020, 0x3F},  // THSPREPARE[15:0]
    	{0x4022, 0x6F},  // THSZERO[15:0]
    	{0x4024, 0x3F},  // THSTRAIL[15:0]
    	{0x4026, 0x5F},  // THSEXIT[15:0]
    	{0x4028, 0x2F},  // TLPX[15:0]
    	{0x4074, 0x01},  // INCKSEL7 [2:0]
    	{REG_NULL, 0x00},
    static const struct imx415_mode supported_modes[] = {
    	 * frame rate = 1 / (Vtt * 1H) = 1 / (VMAX * 1H)
    	 * VMAX >= (PIX_VWIDTH / 2) + 46 = height + 46
    		.bus_fmt = MEDIA_BUS_FMT_SGBRG10_1X10,
    		.width = 1920,
    		.height = 1080,
    		.max_fps = {
    			.numerator = 10000,
    			.denominator = 600000,
    		.exp_def = 0x08ca - 0x08,
    		.hts_def = 0x0226 * IMX415_4LANES * 2,
    		.vts_def = 0x08ca,
    		.global_reg_list = imx415_global_10bit_3864x2192_regs,
    		.reg_list = imx415_linear_10bit_1920x1080_891M_regs,
    		.hdr_mode = NO_HDR,
    		.mipi_freq_idx = 1,
    		.bpp = 10,
    		.vc[PAD0] = 0,
    		.xvclk = IMX415_XVCLK_FREQ_37M,
    Note: If you use the IMX415 driver with 1920x1080 resolution, you need to comment out the following content in /oem/usr/bin/RkLunch.sh.
    	csi_unite=$(( $(luckfox-config get_csi_unite) ))
    	if [ -z csi_unite ]; then
    		csi_unite=0
    	fi
    	if lsmod | grep 'imx415' | awk '{print $3}' | grep -w 1; then
    		if [ $csi_unite == "0" ]; then
    			luckfox-config set_csi_unite 1
    			echo "[rkipc] Set rockchip,unite to 1; rkipc requires a reboot to function properly."
    			return
    		fi
    	else
    		if [ $csi_unite == "1" ]; then
    			luckfox-config set_csi_unite 0
    			echo "[rkipc] Set rockchip,unite to 0; rkipc requires a reboot to function properly."
    			return
    		fi
    	fi
  • Hi Crocodile,
    Thanks a lot for your help. By editing the ./sysdrv/source/kernel/drivers/media/i2c/imx415.c and ./project/app/rkipc/rkipc/src/rv1106_ipc/RkLunch.sh and building the new image, I was able to get close to 1080p@30FPS.
    I also had to update /userdata/rkipc.ini and change the resolution and FPS to achieve 1080p@30FPS.
    The driver code you shared has this:
    		.width = 1920,
    		.height = 1080,
    		.max_fps = {
    			.numerator = 10000,
    So I am assuming it is capable of 1920x1080@60 FPS. In my tests, it always defaults to 30FPS:
    ffprobe -v error -select_streams v:0 -show_entries stream
    =codec_name,width,height,avg_frame_rate,r_frame_rate,nb_frames -of default=nopri
    nt_wrappers=1 /userdata/video0/20240101000107.mp4
    codec_name=hevc
    width=1920
    height=1080
    r_frame_rate=30/1
    avg_frame_rate=30/1
    nb_frames=296
    These are the settings I have kept in my /userdata/rkipc.ini:
    [audio.0]
    enable = 0
    card_name = default
    encode_type = G711A
    format = S16
    sample_rate = 16000
    channels = 2
    frame_size = 1152
    bit_rate = 32000
    input = mic_in
    volume = 50
    [video.source]
    enable_aiq = 1
    enable_vo = 0
    vo_dev_id = 3 ; 0 is mipi, 3 is hdmi
    enable_ivs = 1
    enable_jpeg = 0
    enable_venc_0 = 1
    enable_venc_1 = 0
    enable_venc_2 = 0
    enable_npu = 0
    npu_fps = 10
    enable_rtsp = 0
    enable_rtmp = 0
    [video.0]
    buffer_size = 1036800
    buffer_count = 4
    enable_refer_buffer_share = 1
    stream_type = mainStream
    video_type = compositeStream
    max_width = 1920
    max_height = 1080
    width = 1920
    height = 1080
    rc_mode = VBR
    rc_quality = high
    src_frame_rate_den = 1
    src_frame_rate_num = 60
    dst_frame_rate_den = 1
    dst_frame_rate_num = 60
    target_rate = 8192
    max_rate = 16384
    min_rate = 0
    output_data_type = H.265
    smart = close
    h264_profile = high
    gop = 30
    smartp_viridrlen = 25
    gop_mode = normalP
    stream_smooth = 50
    [ivs]
    smear = 0
    weightp = 0
    md = 0
    od = 0
    md_sensibility = 3 ;available: 1 2 3,max 3
    [isp.0.adjustment]
    contrast    = 50
    brightness  = 50
    saturation  = 50
    sharpness  = 50
    fps = 60
    hue = 50
    [isp.0.video_adjustment]
    image_flip = close
    scene_mode = indoor
    power_line_frequency_mode = NTSC(60HZ)
    [storage.0]
    enable = 1
    folder_name = video0
    file_format = mp4 ; flv,ts
    file_duration = 10
    video_quota = 30
    I know this is a bit greedy but do you have any additional tips/pointers to help achieve 1080p@60FPS? Is this even possible to achieve on the Luckfox Pico Zero?
    Thanks a lot for the help!
