issue: tailscale not using daemon and does not automatically connect on reboot
Posted: 2026-05-28 21:07
by tetra.acid
I’m running PiKVM with:
app: 0.1.3
system: 0.1.7
Tailscale: 1.99.0-dev20260515
Tailscale works fine once started via the web UI, and connectivity is stable.
However, after reboot the device does not reconnect automatically. Tailscale shows as disconnected until I manually click “connect” in the web interface.
It appears tailscaled is not being started automatically at boot. Current workaround is manually starting/connecting after each reboot.
Please can this bug be patched?
Thanks.
Re: issue: tailscale not using daemon and does not automatically connect on reboot
Posted: 2026-06-08 3:49
Thank you for your feedback. We will document it and try to reproduce the issue. Once the problem is identified, we will release an update as soon as possible.
