Hi everyone,
I am working on a system setup using Luckfox Pico Mini with an SC3336 camera module and a 2.4 GHz Wi-Fi transceiver. My goal is to stream video at 1080x1280 resolution over 2.4 GHz with the lowest possible latency.
I have a few specific questions for the community:
Hardware H.264/H.265 Encoding (RKMPP): Has anyone successfully streamed 1080x1280 (or ~1.3MP) at 25-30 FPS using the hardware encoder (RKMPP / luckfox_rtsp_mpi) without hitting RAM limits?
Latency & Protocol: To avoid the 2-3s delay mentioned in some RTSP implementations, is UDP/RTP (or GStreamer Pipeline) recommended on Luckfox Pico Mini for real-time streaming? What is the lowest latency (in ms) achieved so far?
Bitrate Tuning for 2.4 GHz: What bitrate (CBR) settings and GOP/Keyframe intervals do you suggest to maintain a stable stream through walls on 2.4 GHz Wi-Fi?
Any code snippets, GStreamer pipelines, or SDK configuration tips would be greatly appreciated!
