Luckfox Pico Ultra w的休眠调试
  • 您好,正确的设备树应该如下,gpio-keys节点没有创建要放在根节点下
    // SPDX-License-Identifier: (GPL-2.0+ OR MIT)
     * Copyright (c) 2022 Rockchip Electronics Co., Ltd.
    /dts-v1/;
    #include "rv1106.dtsi"
    #include "rv1106-luckfox-pico-ultra-ipc.dtsi"
    #include <dt-bindings/input/input.h>
    #include <dt-bindings/display/media-bus-format.h>
    	model = "Luckfox Pico Ultra W";
    	compatible = "rockchip,rv1103g-38x38-ipc-v10", "rockchip,rv1106g3";
    	restart-poweroff {
    		compatible = "restart-poweroff";
    	sdio_pwrseq: sdio-pwrseq {
    		compatible = "mmc-pwrseq-simple";
    		pinctrl-names = "default";
    		reset-gpios = <&gpio1 RK_PA2 GPIO_ACTIVE_LOW>;
      wireless_bluetooth: wireless-bluetooth {
        compatible = "bluetooth-platdata";
        uart_rts_gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>;
        pinctrl-names = "default", "rts_gpio";
        pinctrl-0 = <&uart1m0_rtsn>;
        pinctrl-1 = <&uart1_gpios>;
        BT,wake_gpio     = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>;
        BT,wake_host_irq = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>;
        status = "okay";
      	gpio-keys {
    		compatible = "gpio-keys";
    		autorepeat;
    		pinctrl-0 = <&pwr_key>;
    		power-key {
    			gpios = <&gpio1 RK_PB0 GPIO_ACTIVE_HIGH>;
    			linux,code = <KEY_POWER>;
    			label ="GPIO Key Power";
    			debounce-interval = <100>;
    			wakeup-source;
    /**********CRU**********/
    //&cru {
    //	assigned-clocks =
    //		<&cru PLL_GPLL>, <&cru PLL_CPLL>,
    //		<&cru ARMCLK>,
    //		<&cru ACLK_PERI_ROOT>, <&cru HCLK_PERI_ROOT>,
    //		<&cru PCLK_PERI_ROOT>, <&cru ACLK_BUS_ROOT>,
    //		<&cru PCLK_TOP_ROOT>, <&cru PCLK_PMU_ROOT>,
    //		<&cru HCLK_PMU_ROOT>, <&cru CLK_500M_SRC>;
    //	assigned-clock-rates =
    //		<1188000000>, <700000000>,
    //		<1104000000>,
    //		<400000000>, <200000000>,
    //		<100000000>, <300000000>,
    //		<100000000>, <100000000>,
    //		<200000000>, <700000000>;
    /**********NPU**********/
    //&npu {
    //	assigned-clock-rates = <700000000>;
    /**********EMMC**********/
    &emmc {
    	bus-width = <8>;
    	cap-mmc-highspeed;
    	non-removable;
    	// mmc-hs200-1_8v;
    	rockchip,default-sample-phase = <90>;
    	no-sdio;
    	no-sd;
    	memory-region-ecsd = <&mmc_ecsd>;
    	post-power-on-delay-ms = <0>;
    	status = "okay";
    &fiq_debugger {
    	rockchip,irq-mode-enable = <1>;
    	status = "okay";
    /**********SDIO-WIFI**********/
    &sdmmc {
            max-frequency = <50000000>;
            bus-width = <4>;
            cap-sd-highspeed;
            cap-sdio-irq;
            keep-power-in-suspend;
            non-removable;
            // no-sd;
            // no-mmc;
            supports-sdio;
            mmc-pwrseq = <&sdio_pwrseq>;
            pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_bus4 &sdmmc0_det>;
            status = "okay";
    &pinctrl{
    	sdmmc0{
    		sdmmc0_det: sdmmc0-det {
    			rockchip,pins =
    				/* sdmmc0_det */
    				<3 RK_PA1 1 &pcfg_pull_down>;
    /***********I2C2**********/
    &panel {
            status = "disabled";
    &rgb {
    &rgb_in_vop {
    &route_rgb {
    &vop {
    /**********I2C**********/
    &i2c2 {
    	status="okay";
    	clock-frequency=<400000>;
    	pinctrl-names="default";
    	pinctrl-0=<&i2c2m0_xfer>;
    /**********ETH**********/
    &gmac {
    	status = "okay";
    /**********USB**********/
    &usbdrd_dwc3 {
    	status = "okay";
    	#dr_mode = "peripheral";
      	dr_mode = "host";
    /**********RTC**********/
    &rtc {
    	status = "okay";
    /**********BT**********/
    &uart1 {
    	status = "okay";
    	pinctrl-0 = <&uart1m0_xfer &uart1m0_ctsn>;
    &pinctrl {
        uart1_gpios: uart1-gpios {
          rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
    /**********SPI**********/
    &spi0 {
    	spidev@0 {
    /**********UART5**********/
    &uart5 {
    	pinctrl-0 = <&uart5m1_xfer>;
    &uart2 { status = "okay";
    	pinctrl-0 = <&uart2m0_xfer>;
    &pinctrl {
    	buttons {
    		pwr_key:pwr-key{
    			rockchip,pins = <1 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>;
