I am using Luckfox Lyra ultra w
I am trying to run a project using docker and docker compose
But I can't use docker because of various errors
The most common error is network bridge not found
Can you tell me how to use it?
Is docker available on Luckfox Lyra?
Hello, the use of docker generally requires the kernel to open iptable NAT bridge cgroup and other configurations, here is a copy of Luckfox-pico to add docker support configuration as a reference, note that Luckfox-pico uses kernel-5.10 and Luckfox-Lyra uses kernel-6.1, some configuration items are different
CONFIG_POSIX_MQUEUE=y
CONFIG_CGROUPS=y
CONFIG_MEMCG=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_SCHED=y
CONFIG_CFS_BANDWIDTH=y
CONFIG_RT_GROUP_SCHED=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_RDMA=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_CGROUP_DEBUG=y
CONFIG_NAMESPACES=y
CONFIG_USER_NS=y
CONFIG_NETFILTER=y
CONFIG_NF_CONNTRACK=y
CONFIG_NF_TABLES=y
CONFIG_NFT_MASQ=y
CONFIG_NFT_REDIR=y
CONFIG_NFT_NAT=y
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=y
CONFIG_NETFILTER_XT_MATCH_CGROUP=y
CONFIG_NETFILTER_XT_MATCH_COMMENT=y
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=y
CONFIG_NF_TABLES_IPV4=y
CONFIG_IP_NF_IPTABLES=y
CONFIG_IP_NF_FILTER=y
CONFIG_IP_NF_NAT=y
CONFIG_IP_NF_TARGET_MASQUERADE=y
CONFIG_IP6_NF_IPTABLES=m
CONFIG_NF_TABLES_BRIDGE=m
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE=m
CONFIG_NET_SCHED=y
CONFIG_NET_CLS_CGROUP=y
CONFIG_CGROUP_NET_PRIO=y
CONFIG_VETH=y
CONFIG_OVERLAY_FS=y
Thanks for the reply. Do I need to rebuild the kernel?
Yes, you need to recompile the kernel
The new version only adds support for luckfox-config
We can't meet every customer's customization needs for the system, thank you for your understanding
