Page 2 of 2
Re: Writing an app using buildroot
Posted: 2024-01-30 12:23
by Robbal
Ok Sorted.
For anybody else . its important where you put the includes. Heres mine for example
cmake_minimum_required(VERSION 3.4.1)
project(rknn_yolov5_demo)
set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -Wl,--allow-shlib-undefined")
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++11 -Wl,--allow-shlib-undefined")
# install target and libraries
set(CMAKE_INSTALL_PREFIX ${CMAKE_SOURCE_DIR}/install/rknn_yolov5_demo_${CMAKE_SYSTEM_NAME})
set(CMAKE_SKIP_INSTALL_RPATH FALSE)
set(CMAKE_BUILD_WITH_INSTALL_RPATH TRUE)
set(CMAKE_INSTALL_RPATH "${CMAKE_INSTALL_PREFIX}/lib")
# rknn api
set(RKNN_API_PATH ${CMAKE_SOURCE_DIR}/../../../runtime/RV1106/${CMAKE_SYSTEM_NAME}/librknn_api)
set(RKNN_RT_LIB ${RKNN_API_PATH}/armhf/librknnmrt.so)
#Set header file search path
include_directories(/home/Projects/luckfox/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/output/host/arm-buildroot-linux-uclibcgnueabihf/sysroot/usr/include)
#Set library file search path
link_directories(/home/Projects/luckfox/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/output/host/arm-buildroot-linux-uclibcgnueabihf/sysroot/usr/lib)
include_directories(${RKNN_API_PATH}/include)
include_directories(${CMAKE_SOURCE_DIR}/../../3rdparty)
# rknn_yolov5_demo
include_directories(${CMAKE_SOURCE_DIR}/include)
add_executable(rknn_yolov5_demo
            src/main.cc
            src/postprocess.cc
target_link_libraries(rknn_yolov5_demo curl
${RKNN_RT_LIB}
install(TARGETS rknn_yolov5_demo DESTINATION ./)
install(PROGRAMS ${RKNN_RT_LIB} DESTINATION lib)
install(DIRECTORY model DESTINATION ./)
Thanks for the help guys
Posted: 2024-01-31 1:09
by Eng38
Thank you for sharing! I believe this will be helpful to many others facing the same issue.
