Luckfox Pico Ultra W - no wifi, no video
  • Hello, please provide the log of serial output after connecting the power supply (using USB to serial module)
  • Sorry for delay - I had thought my post was unsuccessful.
    I logged in with ssh 172.32.0.93 over USB but I don't know what you mean by 'serial log' so I post what I can here:
    rkipc is not running but when I try manually:
    [root@lfu-1 root]# rkipc
    [rkipc.c][main]:rkipc_ini_path_ is (null), rkipc_iq_file_path_ is (null), rkipc_log_level is 2
    [param.c][rk_param_init]:g_ini_path_ is /userdata/rkipc.ini
    [rockiva.c][rkipc_rockiva_init]:begin
    [network.c][rk_net_proc]:Creat rk_net_proc thread!
    [rockiva.c][rkipc_rockiva_init]:ROCKIVA_Init over
    [rockiva.c][rkipc_rockiva_init]:(0,0), (9943,0), (9943,11666), (0,11666)
    [rockiva.c][rkipc_rockiva_init]:ROCKIVA_BA_Init success
    create rknn_list success
    [rockiva.c][rkipc_rockiva_init]:end
    [isp.c][rk_isp_init]:g_iq_file_dir_ is /etc/iqfiles
    [isp.c][rk_isp_init]:cam_id is 0, hdr_mode is close, scenario is normal
    rkaiq log level ff0
    [isp.c][sample_common_isp_init]:ID: 0, sensor_name is ֮1, iqfiles is /etc/iqfiles
    [isp.c][sample_common_isp_init]:main_scene is normal, sub_scene is day
    [isp.c][sample_common_isp_init]:02:10:59.028464: rk_aiq_uapi2_sysctl_preInit_scene begin
    [isp.c][sample_common_isp_init]:02:10:59.028684: rk_aiq_uapi2_sysctl_preInit_scene over
    Segmentation fault (core dumped)
    Here is the dmesg:
    [root@lfu-1 root]# dmesg
    [    2.881345] rkcif rkcif-mipi-lvds: rkcif driver version: v00.01.0a
    [    2.881460] rkcif rkcif-mipi-lvds: attach to cif hw node
    [    2.881485] rkcif rkcif-mipi-lvds: failed to get dphy hw node
    [    2.881496] rkcif rkcif-mipi-lvds: rkcif wait line 0
    [    2.881509] : terminal subdev does not exist
    [    2.881518] : terminal subdev does not exist
    [    2.881525] : terminal subdev does not exist
    [    2.881531] : terminal subdev does not exist
    [    2.881542] : get_remote_sensor: video pad[0] is null
    [    2.881549] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
    [    2.881561] : get_remote_sensor: video pad[0] is null
    [    2.881567] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
    [    2.881575] : get_remote_sensor: video pad[0] is null
    [    2.881582] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
    [    2.881589] : get_remote_sensor: video pad[0] is null
    [    2.881596] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
    [    2.893957] rkcif rkcif-mipi-lvds: No memory-region-thunderboot specified
    [    2.898139] rkcif rkcif-mipi-lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
    [    2.898169] rockchip-mipi-csi2: Async registered subdev
    [    2.898179] rockchip-mipi-csi2: probe success, v4l2_dev:rkcif-mipi-lvds!
    [    2.923333] rkisp_hw ffa00000.rkisp: is_thunderboot: 0
    [    2.923358] rkisp_hw ffa00000.rkisp: max input:0x0@0fps
    [    2.923368] rkisp_hw ffa00000.rkisp: Missing rockchip,grf property
    [    2.923871] rkisp_hw ffa00000.rkisp: get sram size:258048
    [    2.923887] rkisp_hw ffa00000.rkisp: no iommu attached, using non-iommu buffers
    [    2.923897] rkisp_hw ffa00000.rkisp: No reserved memory region. default cma area!
    [    2.928144] rkisp rkisp-vir0: rkisp driver version: v02.00.00
    [    2.930064] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
    [    2.971019] rockchip-csi2-dphy-hw ff3e8000.csi2-dphy-hw: csi2 dphy hw probe successfully!
    [    2.995994] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
    [    3.085924] rkcif rkcif-mipi-lvds: clear unready subdev num: 3
    [    3.085958] rockchip-csi2-dphy0: No link between dphy and sensor
    [    3.087022] rockchip-csi2-dphy0: No link between dphy and sensor
    [    3.087078] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
    [    3.087090] rkcif-mipi-lvds: Async subdev notifier completed
    [    3.087098] rockchip-csi2-dphy0: No link between dphy and sensor
    [    3.087130] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
    [    3.087139] rkcif-mipi-lvds: There is not terminal subdev, not synchronized with ISP
    [    3.087418] rkisp rkisp-vir0: clear unready subdev num: 1
    [    3.087613] rockchip-csi2-dphy0: No link between dphy and sensor
    [    3.087655] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
    [    3.087663] rkcif-mipi-lvds: There is not terminal subdev, not synchronized with ISP
    [    3.088213] rkisp-vir0: Async subdev notifier completed
    [    3.111264] rga: rga2, irq = 38, match scheduler
    [    3.113530] rga: rga2 hardware loaded successfully, hw_version:3.3.87975.
    [    3.113557] rga: rga2 probe successfully
    [    3.114484] rga_iommu: IOMMU binding successfully, default mapping core[0x4]
    [    3.115874] rga: Module initialized. v1.2.23
    [    3.142368] mpp_vcodec: loading out-of-tree module taints kernel.
    [    3.162930] mpp_vcodec: init new
    [    3.163325] mpp_service mpp-srv: 3760314f author: Zhihua Wang 2023-01-12 [vcodec]: check chan create when destroy
    [    3.163341] mpp_service mpp-srv: probe start
    [    3.168619] mpp_rkvenc_540c ffa50000.rkvenc: probing start
    [    3.169786] mpp_rkvenc_540c ffa50000.rkvenc: probing finish
    [    3.170253] mpp_vepu_pp ffa60000.rkvenc-pp: probe device
    [    3.170355] mpp_vepu_pp ffa60000.rkvenc-pp: shared_rst_a_pp is not found!
    [    3.170366] vepu_pp_init:528: No aclk reset resource define
    [    3.170376] mpp_vepu_pp ffa60000.rkvenc-pp: shared_rst_h_pp is not found!
    [    3.170383] vepu_pp_init:531: No hclk reset resource define
    [    3.173219] mpp_vepu_pp ffa60000.rkvenc-pp: probing finish
    [    3.173509] mpp_service mpp-srv: probe success
    [    3.195014] RKNPU ff660000.npu: RKNPU: rknpu iommu device-tree entry not found!, using non-iommu mode
    [    3.197285] RKNPU ff660000.npu: RKNPU: Initialized RKNPU driver: v0.8.2 for 20220829
    [    3.197397] RKNPU ff660000.npu: dev_pm_opp_set_regulators: no regulator (rknpu) found: -19
    [    3.338252] rockit_load start
    [    3.358623] rockit_load end
    [    3.681493] udevd[281]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video1': No such file or directory
    [    3.682606] rk_gmac-dwmac ffa80000.ethernet eth0: PHY [stmmac-0:02] driver [RK630 PHY] (irq=POLL)
    [    3.683020] dwmac4: Master AXI performs any burst length
    [    3.683053] rk_gmac-dwmac ffa80000.ethernet eth0: No Safety Features support found
    [    3.683071] rk_gmac-dwmac ffa80000.ethernet eth0: PTP not supported by HW
    [    3.683374] rk_gmac-dwmac ffa80000.ethernet eth0: configuring for phy/rmii link mode
    [    3.686822] udevd[284]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video4': No such file or directory
    [    3.687943] udevd[285]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video5': No such file or directory
    [    3.689584] udevd[286]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video6': No such file or directory
    [    3.690988] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    3.693297] udevd[280]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video0': No such file or directory
    [    3.695992] udevd[282]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video2': No such file or directory
    [    3.703797] udevd[283]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video3': No such file or directory
    [    3.842832] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    3.843048] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    3.843065] cfg80211: failed to load regulatory.db
    [    4.087489] aicbsp_init
    [    4.087519] RELEASE_DATE:2023_1219_3cf85031
    [    4.087526] aicbsp_resv_mem_init
    [    4.193036] file system registered
    [    4.237422] using random self ethernet address
    [    4.237455] using random host ethernet address
    [    4.279834] Mass Storage Function, version: 2009/09/11
    [    4.279931] LUN: removable file: (no medium)
    [    4.339245] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
    [    4.339274] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
    [    4.339281] aicbsp: aicbsp_platform_power_on
    [    4.339513] func_num = 1
    [    4.341558] VID:c8a1 DID:C18D
    [    4.343951] aicbsp: aicbsp_platform_power_on Get semaphore ...
    [    4.343970] aicbsp: aicbsp_platform_power_on Get semaphore success
    [    4.397748] aicbsp: aicbsp_sdio_probe:1 vid:0xC8A1  did:0xC08D
    [    4.397917] aicbsp: aicbsp_sdio_probe:2 vid:0xC8A1  did:0xC18D
    [    4.397929] aicbsp: aicbsp_sdio_probe after replace:1
    [    4.397939] AICWFDBG(LOGINFO)	aicwf_sdio_chipmatch USE AIC8800DC
    [    4.397945] the device is PRODUCT_ID_AIC8800DC
    [    4.397954] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 10 MHz
    [    4.397960] aicbsp: aicwf_sdio_reg_init
    [    4.398239] mmc_host mmc1: Bus speed (slot 0) = 9900000Hz (slot req 10000000Hz, actual 9900000HZ div = 0)
    [    4.398258] aicbsp: Set SDIO Clock 10 MHz
    [    4.412489] AICWFDBG(LOGINFO)	btenable = 1
    [    4.412512] AICWFDBG(LOGINFO)	aicbsp: aicbsp_driver_fw_init, chip rev: 7
    [    4.412527] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fw_patch_table_8800dc_u02.bin
    [    4.414168] file md5:82e06abe5635a5fb4220a43c1b02e12d
    [    4.414277] rwnx_plat_bin_fw_upload_android
    [    4.414290] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fw_adid_8800dc_u02.bin
    [    4.414792] file md5:95d10e6288e4d3413c0e3508cb9d711a
    [    4.419070] rwnx_plat_bin_fw_upload_android
    [    4.419094] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fw_patch_8800dc_u02.bin
    [    4.420413] file md5:eafad2bf13af789f064ca2363cd99639
    [    4.472332] aicbt_patch_table_load bt btmode[1]:1
    [    4.472354] aicbt_patch_table_load bt uart_baud[1]:115200
    [    4.472362] aicbt_patch_table_load bt uart_flowctrl[1]:1
    [    4.472368] aicbt_patch_table_load bt lpm_enable[1]:0
    [    4.472374] aicbt_patch_table_load bt tx_pwr[1]:28463
    [    4.489903] aicbsp: bt patch version: - Dec 19 2023 12:17:17 - git 7ed06a6
    [    4.489979] ############ aicwifi_init begin
    [    4.492823] AICWFDBG(LOGINFO)	chip_id=7, chip_sub_id=1!!
    [    4.493931] AICWFDBG(LOGDEBUG)	[0x40500010]=6
    [    4.516592] ############ system_config_8800dc done
    [    4.516616] AICWFDBG(LOGTRACE)	>>> rwnx_plat_patch_load()
    [    4.516624] AICWFDBG(LOGINFO)	testmode=0
    [    4.516631] AICWFDBG(LOGINFO)	rwnx_plat_patch_loading
    [    4.516637] u02 is loaing ###############
    [    4.516644] rwnx_plat_bin_fw_upload_android
    [    4.516653] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fmacfw_patch_8800dc_u02.bin
    [    4.518555] file md5:990dc8bafe2a5b687340781a8e1097d7
    [    4.546138] AICWFDBG(LOGINFO)	dpd calib & write
    [    4.546162] aicwf_dpd_calib_8800dc
    [    4.546630] AICWFDBG(LOGERROR)	misc_ram_addr=120ebc
    [    4.548531] AICWFDBG(LOGTRACE)	bit_mask:e5fad053,c9e703c4,1ca97f74,15ccabcc
    [    4.548551] rwnx_plat_bin_fw_upload_android
    [    4.548562] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fmacfw_calib_8800dc_u02.bin
    [    4.550726] file md5:ce762bb296e3e45f4405d7cd5ff2961a
    [    4.580012] AICWFDBG(LOGINFO)	Start app: 00130009, 4
    [    4.604716] read descriptors
    [    4.604750] read strings
    [    4.830193] ############ rwnx_plat_patch_load done
    [    4.831699] AICWFDBG(LOGINFO)	wifisetting_cfg_addr=11019c, ldpc_cfg_addr=120980, agc_cfg_addr=120180, txgain_cfg_addr=120000
    [    4.837735] ### Upload fmacfw_patch_tbl_8800dc_u02.bin
    [    4.837761] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fmacfw_patch_tbl_8800dc_u02.bin
    [    4.858928] file md5:0de84344e8d8df79b1e7286d2cd6355e
    [    4.858957] tbl size = 728
    [    4.858972] AICWFDBG(LOGINFO)	FMACFW_PATCH_TBL_8800DC_U02_DESCRIBE_BASE = 187c00
    [    4.860981] mi Dec 19 2023 12:34:22 - g31c7979
    [    4.860998] patch_tbl:  110888  180e05
    [    4.861498] patch_tbl:  1108ec  184a79
    [    4.861948] patch_tbl:  110874  180e5d
    [    4.863542] patch_tbl:  110658  1816ed
    [    4.864030] patch_tbl:  1107dc  18177d
    [    4.864483] patch_tbl:  1107e0  181a9d
    [    4.864928] patch_tbl:  110838  181b01
    [    4.866147] patch_tbl:  110490  183425
    [    4.866641] patch_tbl:  110420  1826d1
    [    4.867097] patch_tbl:  11048c  1827ed
    [    4.867545] patch_tbl:  110688  182891
    [    4.867986] patch_tbl:  110738  1832cd
    [    4.868416] patch_tbl:  110554  183479
    [    4.869555] patch_tbl:  110798  183afd
    [    4.869963] patch_tbl:  1106dc  183519
    [    4.870342] patch_tbl:  110584  183571
    [    4.870717] patch_tbl:  110588  183749
    [    4.871090] patch_tbl:  110634  185631
    [    4.871459] patch_tbl:  110638  185811
    [    4.871829] patch_tbl:  11086c  185a29
    [    4.872869] patch_tbl:  1105fc  185a85
    [    4.873274] patch_tbl:  1105f0  18643d
    [    4.873665] patch_tbl:  110860  185799
    [    4.874044] patch_tbl:  11081c  1851a1
    [    4.874417] patch_tbl:  1105a4  185d31
    [    4.874785] patch_tbl:  1105c8  185e01
    [    4.875158] patch_tbl:  11064c  1861ad
    [    4.876159] patch_tbl:  110810  185601
    [    4.876566] patch_tbl:  1108c4  183fed
    [    4.876956] patch_tbl:  1108c8  183bf5
    [    4.877332] patch_tbl:  110628  184169
    [    4.877711] patch_tbl:  110758  1867ed
    [    4.878096] patch_tbl:  110750  186c41
    [    4.878464] patch_tbl:  11085c  186f11
    [    4.879605] patch_tbl:  110518  186f51
    [    4.880033] patch_tbl:  1105e0  181c39
    [    4.880427] patch_tbl:  1107d8  183b75
    [    4.880802] patch_tbl:  1103d0  186fb1
    [    4.881177] patch_tbl:  1106c8  18758d
    [    4.881546] patch_tbl:  11056c  187559
    [    4.881922] patch_tbl:  110510  187665
    [    4.882845] patch_tbl:  110550  187701
    [    4.883260] patch_tbl:  110054  1816ed
    [    4.883650] patch_tbl:  11005c  1816ed
    [    4.884023] patch_tbl:  110048  183425
    [    4.884394] patch_tbl:  110088  1859d5
    [    4.884770] patch_tbl:  110ef0  185b89
    [    4.885150] patch_tbl:  110ec0  1865a5
    [    4.886141] patch_tbl:  110da0  1865cd
    [    4.886551] patch_tbl:  110dc0  186789
    [    4.886941] patch_tbl:  110e28  18671d
    [    4.887318] patch_tbl:  1100e0  1866c9
    [    4.887688] patch_tbl:  110d90  186ced
    [    4.888059] patch_tbl:  110e18  186525
    [    4.888430] patch_tbl:  110bb4  1823a5
    [    4.889306] patch_tbl:  1109c0  181d01
    [    4.889714] patch_tbl:  110f08  1826b1
    [    4.890097] patch_tbl:  110b1c  183b01
    [    4.890485] patch_tbl:  110b24  183b01
    [    4.890852] patch_tbl:  110b5c  1829a5
    [    4.891223] patch_tbl:  110b64  1829a5
    [    4.891595] patch_tbl:  110b6c  1829a5
    [    4.891963] patch_tbl:  110b74  1829a5
    [    4.892933] patch_tbl:  110b7c  1829a5
    [    4.893340] patch_tbl:  110b8c  1829a5
    [    4.893733] patch_tbl:  110ac0  184e51
    [    4.894110] patch_tbl:  110aa0  183a91
    [    4.894476] patch_tbl:  110aa8  183ae1
    [    4.894844] patch_tbl:  110a60  1874ad
    [    4.895222] patch_tbl:  110e20  187521
    [    4.896177] patch_tbl:  40030084  187c80
    [    4.896581] patch_tbl:  40030000  2778c
    [    4.896963] patch_tbl:  187c80  47706008
    [    4.897342] patch_tbl:  40030080  1
    [    4.897720] patch_tbl:  4010001c  0
    [    4.898108] ############ aicwf_patch_config_8800dc done
    [    4.898118] AICWFDBG(LOGINFO)	Read FW mem: 00120000
    [    4.898498] AICWFDBG(LOGINFO)	cfm: [00120000] = 00ffd780
    [    4.898508] AICWFDBG(LOGINFO)	Start app: 00120000, 5
    [    4.903111] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 10 MHz
    [    4.903126] aicsdio: aicwf_sdio_reg_init
    [    4.908716] aicbsp: aicbsp_resv_mem_alloc_skb, alloc resv_mem_txdata succuss, id: 0, size: 98304
    [    4.909600] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 10 MHz
    [    4.909783] AICWFDBG(LOGINFO)	aicwf_prealloc_txq_alloc size is diff will to be kzalloc
    [    4.909812] AICWFDBG(LOGINFO)	aicwf_prealloc_txq_alloc txq kzalloc successful
    [    4.935361] aicbsp: sdio_err:<aicwf_sdio_bus_pwrctl,1392>: bus down
    [    5.175653] ieee80211 phy0: HT supp 1, VHT supp 1, HE supp 1
    [    5.179053] ieee80211 phy0:
    [    5.179053] *******************************************************
    [    5.179053] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES **
    [    5.599112] usb0: HOST MAC 7a:27:b2:b8:e3:d3
    [    5.599134] usb0: MAC 4a:b9:53:dc:9b:5a
    [    5.724305] dwc3 ffb00000.usb: device reset
    [    5.841601] dwc3 ffb00000.usb: device reset
    [    5.966201] android_work: sent uevent USB_STATE=CONNECTED
    [    5.972427] android_work: sent uevent USB_STATE=CONFIGURED
    [    6.718398] of_dma_request_slave_channel: dma-names property of node '/serial@ff4b0000' missing or empty
    [    6.718490] dw-apb-uart ff4b0000.serial: failed to request DMA, use interrupt mode
    [    7.251911] aic_bluetooth_mod_init
    [    7.255429] -->rfkill_bluetooth_init
    [    7.257271] <--rfkill_bluetooth_init
    [   10.195590] rwnx_send_sm_connect_req drv_vif_index:0 connect to Moldova(7) channel:2462 auth_type:0
    [   38.093049] deinit:macaddr:28,3d,e8,83,5b,66
    [   38.093073] reord_mac:28,3d,e8,83,5b,66
    [   38.098074] rwnx_send_sm_connect_req drv_vif_index:0 connect to Moldova(7) channel:2462 auth_type:0
    [   38.112649] debugfs: Directory 'b4:75:0e:30:f1:4e' with parent 'rc' already present!
    [   38.112685] aicwf_sdio mmc1:7a8a:1: Error while (un)registering debug entry for sta 1
  • Sorry for not expressing clearly what “serial log” means “serial port log”. Compared with dmesg, the information will be more complete.
    According to the log you provided, rkipc is not running. It may be that CSI is not turned on in luckfox-config (you can use i2cdetect - y 4 Check whether 0x30 is UU to verify)
    From the log, wlan0 should be working normally (use ifconfig -a to check whether there is wlan0 to verify). If wlan0 is not working properly, please provide the information after lsmod and the complete serial port log
  • I have got wlan0 working since I first posted but my main problem now is a non-functional camera. I bought a second camera in case it was a hardware problem but it made no difference (and yes - they are connected correctly).
    In order to get wifi working I had to put in a /etc/init.d job as follows:
    [root@lfu-1 root]# cat /etc/init.d/S99dhcp
    #!/bin/sh
    case $1 in
    start)
                sleep 30
                killall -9 udhcpc
                killall -9 wpa_supplicant
                wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant.conf
    	   udhcpc -i wlan0
    	exit 1
    esac
    luckfox-config crashes (and /proc/device-tree/model has a null at the end - weird?):
    /usr/bin/luckfox-config: line 46: warning: command substitution: ignored null byte in input
    [root@lfu-1 root]# i2cdetect -y 4
    i2cdetect: can't open '/dev/i2c/4': No such file or directory
    [root@lfu-1 root]# lsmod
    Module                  Size  Used by    Tainted: G
    aic8800_btlpm           1719  0
    aic8800_fdrv          299531  0
    aic8800_bsp            50318  2 aic8800_btlpm,aic8800_fdrv
    ccm                     6847  0
    ctr                     2606  0
    libarc4                  799  0
    cfg80211              168757  1 aic8800_fdrv
    rockit                154528  0
    rknpu                  22683  0
    mpp_vcodec            375759  1 rockit
    rga3                   87738  1 rockit
    sc3336                  9940  0
    sc4336                  9196  0
    os04a10                15198  0
    phy_rockchip_csi2_dphy     7674  0
    phy_rockchip_csi2_dphy_hw     8161  0
    video_rkisp           148435  1 rockit
    video_rkcif           130130  0
    rk_dvbm                 5813  2 mpp_vcodec,video_rkisp
  • Executing `luckfox-config` checks the device name, and if there are spaces in the device name, it will raise a warning. This can be ignored (the Luckfox Pico has a space in its name). When `luckfox-config` is executed, a graphical interface will appear. To enable the camera to work properly, you need to enable CSI in the settings, as indicated in the wiki. According to the logs, i2c4 is not functioning correctly, and you can also modify the device tree and re-flash the boot.img image.
    # in <SDK>/config/dts_config
    &i2c4 {
    	pinctrl-names = "default";
    	pinctrl-0 = <&i2c4m2_xfer>;
  • I get no graphical interface with luckfox-config - just the error message.
    I strongly suspect a hardware problem as the pico was OK the first time I used it, and the camera (and wifi) just stopped working after a while without touching it.
    I have already re-flashed the pico with the same image that I used before. Should I do it again?
    By the way - I forgot to say - thanks for your support!!
  • By the way - I did not use the SDK, just the default image on gdrive
  • Your log indicates that executing `i2cdetect -y 4` shows that I2C4 is not functioning properly, which is the reason the camera isn't working. The image in the cloud storage, including the SDK default configuration compiled image for Luckfox Pico Ultra, does not have I2C4 enabled by default (other models have it enabled by default; see the wiki for detailed reasons).If I2C4 is not functioning, the camera definitely cannot work.
    If you cannot open the `luckfox-config` GUI, you can directly modify the device tree to enable I2C4 (you cannot modify the device tree without using the SDK). The reason you might not be able to open the GUI could be due to the terminal device you are using; I tested it successfully in Windows Terminal and WindTerm.
  • You were absolutely correct!! Thank you so much.
    Once I logged in to the pico I did:
    TERM=xterm
    and then I can run luckfox-config and enable CSI. Now I can see the camera!! I would suggest that luckfox-config put out a better error message if it can't use the $TERM variable.
    It's just a little weird that I did not have to do this the first time, but no matter - I'm back in business now.
