I would like to know, when a project is finished for any environment (Ubuntu,buildroot), which files need to be archived so that the project can be started from the same position later? Is only kernel .config buildroot.config and of course .dts enough or are there some other files that need to be saved?
Archive project
Hello, if you don't just modify the files based on the original SDK, the files you mentioned are enough.
Uboot is usually not modified.
