luckfox pico ultra安装openvpn
  • 您好,执行./build.sh buildrootconfig 打开buildroot menuconfig
    #使用 / 搜索 y 添加
    BR2_PACKAGE_OPENVPN
    执行./build.sh kernelconfig 打开内核menuconfig
    #使用 / 搜索 y 添加
    CONFIG_NET_CORE
    CONFIG_TUN
    以上仅供参考,实际使用中可能还需要其他的依赖项,linux是一个复杂的系统,我们没有足够的精力去确定所有功能所依赖的选项,详细请查询相关资料。
  • Hello from Spain,
    I have configured luckfox pico MAX whith openvpn in linux. Here the steps i followed and the solutions i have implemented.
    You need:
    - luckfox pico Boaed, i use rv1106 Pico Max.
    - a SD card, i think almost 8gb XCSD class 10.
    - some time.
    First off all: Follow the wiki instructions for create SD linux: https://wiki.luckfox.com/Luckfox-Pico/L ... nvironment
    Second steep: You need to incorporate TUN capabilities to this SD_linux, you need to modify Kernel like in this wiki post: https://wiki.luckfox.com/Luckfox-Pico/L ... figuration, BUT with the followings components:
    -Universal TUN/TAP device driver support (select with * not by M)
    -> Device Drivers
    -> Network device support
    -> Network core driver support
    - IP:tunneling + Layer Two Tunneling Protocol (L2TP) + IP: FOU encapsulation of IP tunnels (NEW)
    -> Device Drivers
    -> Networking support
    -> Networking options
    - Network Light weight tunnel
    -> Device Drivers
    Third steep: follow the Ubuntu instructions for openvpn in: https://documentation.ubuntu.com/server ... index.html
    Last steep and Notes: when i build it in a WSL, the TUN not work, only work if i follow this steeps in a normal linux system.
    I hope you can follow and configure openvpn properly.
