Max power supply on Pico Mini USB
What is the maximum power available from the Pico Mini's USB port?
Hello, the Pico Mini relies on external power. If you supply power to the Pico Mini through the VBUS pin, the output power of the Pico Mini's USB port depends on your power source. It is not recommended to connect USB devices with power consumption exceeding 15W, as the board design and narrow traces may lead to overheating or damage to the circuit board.
