luckfox.cfg
  • It should be noted that the default port will be occupied by RGB, so you need to disable RGB first. To enable the relevant pins, use luckfox-config or modify the relevant device tree.
    https://wiki.luckfox.com/Luckfox-Pico/L ... -Pico-GPIO
  • We are using luckfox-config config to disable the RGB and the CSI. The problem is that the configuration sometimes does not survive a reboot and the generated luckfox.cfg is overwritten.
  • Settings that need a reboot to take effect are made by directly modifying the dtb. The ENABLE status in luckfox.cfg is only for record. Simply modifying luckfox.cfg does not take effect during configuration loading.
