SDK Build failed with the following error. Any help would be greatly appreciated.
[build.sh:info] Running build_uboot succeeded.
============Start building kernel============
TARGET_ARCH =arm
TARGET_KERNEL_CONFIG =luckfox_rv1106_linux_defconfig
TARGET_KERNEL_DTS =rv1106g-luckfox-pico-ultra-w.dts
TARGET_KERNEL_CONFIG_FRAGMENT =rv1106-bt.config
make: Entering directory '/home/sysdrv'
==sysdrv== build kernel
make -C /home/sysdrv/source/kernel ARCH=arm mrproper
make[1]: Entering directory '/home/sysdrv/source/kernel'
make[2]: *** Documentation/Kbuild: Is a directory. Stop.
make[1]: *** [Makefile:1942: _clean_Documentation] Error 2
make[1]: Leaving directory '/home/sysdrv/source/kernel'
make: *** [Makefile:485: kernel] Error 2
make: Leaving directory '/home/sysdrv'
[build.sh:error] Running build_kernel failed!
[build.sh:error] exit code 2 from line 876:
[build.sh:info] make kernel -C ${SDK_SYSDRV_DIR} $kernel_build_options KERNEL_DTS=${RK_KERNEL_DTS} KERNEL_CFG=${RK_KERNEL_DEFCONFIG} KERNEL_CFG_FRAGMENT=${RK_KERNEL_DEFCONFIG_FRAGMENT}
root@83880300c830:/home#
I am running docker desktop 4.38.0 on MacOS. I recently cloned SDK repo and create docker container.
git clone https://github.com/LuckfoxTECH/luckfox-pico.git
sudo docker run -it --name luckfox --privileged -v /Users/username/luckfox-pico:/home luckfoxtech/luckfox_pico:1.0 /bin/bash
root@83880300c830:/# cd home
root@83880300c830:/home# ./build.sh lunch
ls: cannot access 'BoardConfig*.mk': No such file or directory
You're building on Linux
Lunch menu...pick the Luckfox Pico hardware version:
选择 Luckfox Pico 硬件版本:
[0] RV1103_Luckfox_Pico
[1] RV1103_Luckfox_Pico_Mini_A
[2] RV1103_Luckfox_Pico_Mini_B
[3] RV1103_Luckfox_Pico_Plus
[4] RV1103_Luckfox_Pico_WebBee
[5] RV1106_Luckfox_Pico_Pro
[6] RV1106_Luckfox_Pico_Max
[7] RV1106_Luckfox_Pico_Ultra
[8] RV1106_Luckfox_Pico_Ultra_W
[9] custom
Which would you like? [0~9][default:0]: 8
Lunch menu...pick the boot medium:
选择启动媒介:
[0] EMMC
Which would you like? [0][default:0]:
Lunch menu...pick the system version:
选择系统版本:
[0] Buildroot(Support Rockchip official features)
[1] Ubuntu(Support for the apt package management tool)
Which would you like? [0~1][default:0]:
[build.sh:info] Lunching for Default BoardConfig_IPC/BoardConfig-EMMC-Buildroot-RV1106_Luckfox_Pico_Ultra_W-IPC.mk boards...
[build.sh:info] switching to board: /home/project/cfg/BoardConfig_IPC/BoardConfig-EMMC-Buildroot-RV1106_Luckfox_Pico_Ultra_W-IPC.mk
[build.sh:info] Running build_select_board succeeded.
Hello, if your MAC is M series, the SDK is not supported, the M series MAC is ARM architecture, and the compilation chain used by the SDK is based on X86_64
No, it has intel CPU, not M series.
I noticed that the whole SDK is placed in the /home directory, to avoid abuse of permissions, don't use root privileges to switch ordinary users, and try build the SDK environment under /home/<User name>
Unfortunately, build script yields in same error @ building the kernel :
TARGET_ARCH =arm
make: Entering directory '/home/pico/sysdrv'
make -C /home/pico/sysdrv/source/kernel ARCH=arm mrproper
make[1]: Entering directory '/home/pico/sysdrv/source/kernel'
make[1]: Leaving directory '/home/pico/sysdrv/source/kernel'
make: Leaving directory '/home/pico/sysdrv'
I have deleted previously created docker container and recreate as follows. I also add user:
docker run -it --name luckfox --privileged -v /Users/username/luckfox-pico:/home/pico luckfoxtech/luckfox_pico:1.0 /bin/bash
root@1e6cac5ab8f8:~# adduser
root@1e6cac5ab8f8:~# cd /home/pico
root@1e6cac5ab8f8:/home/pico# su pico
pico@1e6cac5ab8f8:~$ pwd
/home/pico
pico@1e6cac5ab8f8:~$ ./build.sh lunch
[9] custom
选择启动媒介:
[0] EMMC
选择系统版本:
[build.sh:info] switching to board: /home/pico/project/cfg/BoardConfig_IPC/BoardConfig-EMMC-Buildroot-RV1106_Luckfox_Pico_Ultra_W-IPC.mk
Hi Steko. I found this
https://stackoverflow.com/questions/760 ... umentation which sounds very similar to your problem.
In short, you have to download SDK into a case sensitive file system. So you will: clone the SDK into your docker image, or format one of your hard drive partition to a case sensitive file system, or create a virtual disk.
I don't own a Mac, but I still hope this message could help you.
Thank you zhu30844. That very well explains the errors I have been receiving.
I believe having an ubuntu VM and passing thru the usb device for flashing the board is way simpler than reconfiguring the MacOS host. So far so good with this option.
