Problem with Luckfox Pico Plus Not Detecting SD Card in Soctoolkit
Posted: 2025-03-13 20:11
by boozary
I have a Luckfox Pico Plus board. When I insert an SD card, it does not show up in the SD memory section of Soctoolkit, so I can't install the image on it.
However, when I install the OS on NAND, Linux itself mounts the SD card, and I can use it normally.
Is there anything specific I need to do to be able to burn the image to the SD card?
Thanks!
Re: Problem with Luckfox Pico Plus Not Detecting SD Card in Soctoolkit
Posted: 2025-09-14 10:25
by luckfoxforum
The Windows Software doesn't seem to work anymore in general:
https://spotpear.com/LuckFox-Pico-Linux ... r/119.html
And as it seems here support seems to be officially abandoned. The Wiki still references it along with the no longer existing Ubuntu images.
Posted: 2025-09-14 10:28
by luckfoxforum
The only way I get it to show the SD card is by formatting it manually. Which has to be done for each session.
But I never got it to boot. So this might only partially skip the symptoms of the issue.
edit:
Correction, does no longer work.
Posted: 2025-09-20 6:49
SocToolKit is provided by Rockchip. Currently, we do not have an updated version. Personally, during my use, I found that the SD card could only be recognized after the software was turned on. Otherwise, there would often be situations where the computer recognized it but the software did not.
