I finally received my LuckFox Pico Ultra W.
Compiling and flashing Ubuntu image to eMMC was straightforward, no issues at all.
Now, when I run the following command, I can see that microphone can't be detected:
pico@luckfox:~$ arecord -l
arecord: device_list:274: no soundcards found...
pico@luckfox:~$ aplay -l
aplay: device_list:274: no soundcards found...
Below you can find alsa-info output:
!!ALSA Information Script v 0.5.1
!!Script ran on: Thu Apr 10 14:18:41 UTC 2025
!!Linux Distribution
Ubuntu 22.04.5 LTS \n \l DISTRIB_ID=Ubuntu DISTRIB_DESCRIPTION="Ubuntu 22.04.5 LTS" PRETTY_NAME="Ubuntu 22.04.5 LTS" NAME="Ubuntu" ID=ubuntu ID_LIKE=debian HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" UBUNTU_CODENAME=jammy
!!DMI Information
Manufacturer:
Product Name:
Product Version:
Firmware Version:
System SKU:
Board Vendor:
Board Name:
!!ACPI Device Status Information
!!Kernel Information
Kernel release: 5.10.160
Operating System: GNU/Linux
Architecture: armv7l
Processor: armv7l
SMP Enabled: No
!!ALSA Version
Driver version: k5.10.160
Library version: 1.2.6.1
Utilities version: 1.2.6
!!Loaded ALSA modules
!!Sound Servers on this system
No sound servers found.
!!Soundcards recognised by ALSA
0 [rv1106acodec ]: rv1106-acodec - rv1106-acodec
rv1106-acodec
!!PCI Soundcards installed in the system
!!Modprobe options (Sound related)
snd_pcsp: index=-2
snd_usb_audio: index=-2
snd_atiixp_modem: index=-2
snd_intel8x0m: index=-2
snd_via82xx_modem: index=-2
snd_usb_caiaq: index=-2
snd_usb_ua101: index=-2
snd_usb_us122l: index=-2
snd_usb_usx2y: index=-2
snd_cmipci: mpu_port=0x330 fm_port=0x388
snd_pcsp: index=-2
snd_soc_core: prealloc_buffer_size_kbytes=16
!!Loaded sound module options
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/platform/drivers/asoc-simple-card
Tree:
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 0 Apr 10 22:15 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 24 Apr 10 22:15 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 16 Apr 10 22:15 /dev/snd/pcmC0D0p
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Apr 10 22:15 .
drwxr-xr-x 3 root root 120 Apr 10 22:15 ..
lrwxrwxrwx 1 root root 12 Apr 10 22:15 platform-acodec-sound -> ../controlC0
!!Aplay/Arecord output
APLAY
ARECORD
!!Amixer output
!!-------Mixer controls for card rv1106acodec
Invalid card number 'rv1106acodec'.
!!Alsactl output
--startcollapse--
--endcollapse--
!!All Loaded Modules
mpp_vcodec
phy_rockchip_csi2_dphy
phy_rockchip_csi2_dphy_hw
rga3
rk_dvbm
rknpu
rockit
rve
video_rkcif
video_rkisp
!!ALSA/HDA dmesg
[ 0.249854] mmc1: new SDIO card at address 7a8a
[ 0.308174] ALSA device list:
[ 0.308203] #0: rv1106-acodec
!!Packages installed
ii alsa-topology-conf 1.2.5.1-2 all ALSA topology configuration files
ii alsa-ucm-conf 1.2.6.3-1ubuntu1.12 all ALSA Use Case Manager configuration files
ii alsa-utils 1.2.6-1ubuntu1 armhf Utilities for configuring and using ALSA
[ 0.198241] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 2.
[ 0.198261] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 34.
[ 0.198274] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 0.198324] [BT_RFKILL]: Failed to get bt_default_wake_host gpio.
[ 0.198369] rfkill_bt: probe of wireless-bluetooth failed with error -1
[ 0.198445] Key type dns_resolver registered
[ 0.199331] Loading compiled-in X.509 certificates
[ 0.214464] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.227399] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 0.228031] rockchip-pinctrl pinctrl: pin gpio2-1 already requested by ff470000.i2c; cannot claim for ff9a0000.mmc
[ 0.228054] rockchip-pinctrl pinctrl: pin-65 (ff9a0000.mmc) status -22
[ 0.228067] rockchip-pinctrl pinctrl: could not request pin 65 (gpio2-1) from group sdmmc1m0-bus4 on device rockchip-pinctrl
[ 0.228078] dwmmc_rockchip ff9a0000.mmc: Error applying setting, reverse things back
[ 0.228108] dwmmc_rockchip: probe of ff9a0000.mmc failed with error -22
[ 0.239453] mmc1: queuing unknown CIS tuple 0x10 (5 bytes)
[ 0.243735] mmc_host mmc0: Bus speed (slot 0) = 49500000Hz (slot req 52000000Hz, actual 49500000HZ div = 0)
[ 0.243902] mmc0: new high speed MMC card at address 0001
[ 0.244377] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 0.244479] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[ 0.244597] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[ 0.244825] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (247:0)
[ 0.245174] mmc_host mmc1: Bus speed (slot 0) = 49500000Hz (slot req 50000000Hz, actual 49500000HZ div = 0)
[ 0.245477] mmcblk0: p1(env) p2(idblock) p3(uboot) p4(boot) p5(oem) p6(userdata) p7(rootfs)
[ 0.246248] mmc1: queuing unknown CIS tuple 0x10 (5 bytes)
[ 0.313403] EXT4-fs (mmcblk0p7): INFO: recovery required on readonly filesystem
[ 0.313427] EXT4-fs (mmcblk0p7): write access will be enabled during recovery
[ 0.783806] EXT4-fs (mmcblk0p7): recovery complete
[ 0.784905] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 0.784991] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[ 0.785518] devtmpfs: mounted
[ 0.785714] Freeing unused kernel memory: 204K
[ 0.785724] Kernel memory protection not selected by kernel config.
[ 0.785758] Run /sbin/init as init process
[ 0.785764] with arguments:
[ 0.785768] /sbin/init
[ 0.785771] with environment:
[ 0.785775] HOME=/
[ 0.785778] TERM=linux
[ 0.785782] user_debug=31
[ 0.785786] storagemedia=emmc
[ 0.785790] earlycon=uart8250,mmio32,0xff4c0000
[ 1.058092] systemd[1]: Failed to look up module alias 'autofs4': Function not implemented
[ 1.073521] systemd[1]: systemd 249.11-0ubuntu3.15 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 1.074412] systemd[1]: Detected architecture arm.
[ 1.768469] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[ 2.004980] systemd[1]: Queued start job for default target Graphical Interface.
[ 2.009247] systemd[1]: Created slice Slice /system/getty.
[ 2.011512] systemd[1]: Created slice Slice /system/modprobe.
[ 2.013510] systemd[1]: Created slice Slice /system/serial-getty.
[ 2.014691] systemd[1]: Created slice User and Session Slice.
[ 2.015660] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.016573] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.017379] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[ 2.017905] systemd[1]: Reached target Local Encrypted Volumes.
[ 2.018745] systemd[1]: Reached target Remote File Systems.
[ 2.019215] systemd[1]: Reached target Slice Units.
[ 2.019918] systemd[1]: Reached target Local Verity Protected Volumes.
[ 2.021167] systemd[1]: Listening on Syslog Socket.
[ 2.022199] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.035581] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 2.036645] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.038147] systemd[1]: Listening on Journal Socket.
[ 2.040213] systemd[1]: Listening on udev Control Socket.
[ 2.041497] systemd[1]: Listening on udev Kernel Socket.
[ 2.042644] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 2.043268] systemd[1]: Condition check resulted in POSIX Message Queue File System being skipped.
[ 2.046836] systemd[1]: Mounting Kernel Debug File System...
[ 2.047986] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 2.049622] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 2.049666] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 2.062841] systemd[1]: Starting Journal Service...
[ 2.064170] systemd[1]: Condition check resulted in Create List of Static Device Nodes being skipped.
[ 2.076212] systemd[1]: Starting Load Kernel Module configfs...
[ 2.104535] systemd[1]: Starting Load Kernel Module drm...
[ 2.130543] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 2.154056] systemd[1]: Starting Load Kernel Module fuse...
[ 2.184579] systemd[1]: Starting Load Kernel Modules...
[ 2.203474] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 2.222430] systemd[1]: Starting Coldplug All udev Devices...
[ 2.257661] systemd[1]: Mounted Kernel Debug File System.
[ 2.276313] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 2.280187] systemd[1]: Finished Load Kernel Module configfs.
[ 2.314580] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.315781] systemd[1]: Finished Load Kernel Module drm.
[ 2.318337] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 2.335725] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 2.338060] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.348744] systemd[1]: Finished Load Kernel Module fuse.
[ 2.353765] systemd[1]: Finished Load Kernel Modules.
[ 2.357057] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 2.370656] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[ 2.374254] systemd[1]: Mounting Kernel Configuration File System...
[ 2.393327] systemd[1]: Starting Apply Kernel Variables...
[ 2.447701] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 2.448912] systemd[1]: Mounted Kernel Configuration File System.
[ 2.475379] systemd[1]: Activating swap /swapfile...
[ 2.476218] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 2.492236] systemd[1]: Starting Load/Save Random Seed...
[ 2.540061] systemd[1]: Starting Create System Users...
[ 2.556185] Adding 1048572k swap on /swapfile. Priority:-2 extents:3 across:1196028k SS
[ 2.582592] systemd[1]: Activated swap /swapfile.
[ 2.614316] systemd[1]: Finished Apply Kernel Variables.
[ 2.621012] systemd[1]: Reached target Swaps.
[ 2.635955] systemd[1]: Finished Load/Save Random Seed.
[ 2.637101] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 2.734580] systemd[1]: Finished Create System Users.
[ 2.739346] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 2.821604] systemd[1]: Started Journal Service.
[ 2.946083] systemd-journald[83]: Received client request to flush runtime journal.
[ 2.955749] systemd-journald[83]: File /var/log/journal/1fe5d22f36814c0598da7e315031b67d/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 6.719536] EXT4-fs (mmcblk0p6): recovery complete
[ 6.719559] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 6.719590] ext4 filesystem being mounted at /userdata supports timestamps until 2038 (0x7fffffff)
[ 6.731190] EXT4-fs (mmcblk0p5): recovery complete
[ 6.731729] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 10.050381] rk_dvbm ffa70000.rkdvbm: probe start
[ 10.050401] rk_dvbm ffa70000.rkdvbm: dvbm ctx 58bc804d
[ 10.065567] rk_dvbm ffa70000.rkdvbm: probe success
[ 10.121067] sc3336 4-0030: driver version: 00.01.01
[ 10.121160] sc3336 4-0030: Failed to get pwdn-gpios
[ 10.121170] sc3336 4-0030: could not get default pinstate
[ 10.121194] sc3336 4-0030: could not get sleep pinstate
[ 10.121220] sc3336 4-0030: supply avdd not found, using dummy regulator
[ 10.121428] sc3336 4-0030: supply dovdd not found, using dummy regulator
[ 10.121489] sc3336 4-0030: supply dvdd not found, using dummy regulator
[ 10.355536] rk3x-i2c ff470000.i2c: timeout, ipd: 0x00, state: 3
[ 10.355578] sc3336 4-0030: Unexpected sensor id(000000), ret(-5)
[ 10.406458] mis5001 4-0031: driver version: 00.01.02
[ 10.406552] mis5001 4-0031: Failed to get pwdn-gpios
[ 10.406562] mis5001 4-0031: could not get default pinstate
[ 10.406585] mis5001 4-0031: could not get sleep pinstate
[ 10.406610] mis5001 4-0031: supply avdd not found, using dummy regulator
[ 10.406819] mis5001 4-0031: supply dovdd not found, using dummy regulator
[ 10.406880] mis5001 4-0031: supply dvdd not found, using dummy regulator
[ 10.625492] rk3x-i2c ff470000.i2c: timeout, ipd: 0x00, state: 3
[ 10.625532] mis5001 4-0031: Unexpected sensor id(000000), ret(-5)
[ 10.686756] rkcifhw ffa10000.rkcif: no iommu attached, using non-iommu buffers
[ 10.686770] rkcifhw ffa10000.rkcif: No reserved memory region assign to CIF
[ 10.687164] rkcif rkcif-mipi-lvds: rkcif driver version: v00.02.00
[ 10.687310] rkcif rkcif-mipi-lvds: attach to cif hw node
[ 10.687318] rkcif rkcif-mipi-lvds: failed to get dphy hw node
[ 10.687343] rkcif rkcif-mipi-lvds: rkcif wait line 0
[ 10.687351] rkcif rkcif-mipi-lvds: rkcif fastboot reserve bufs num 3
[ 10.687362] : terminal subdev does not exist
[ 10.687374] : terminal subdev does not exist
[ 10.687384] : terminal subdev does not exist
[ 10.687392] : terminal subdev does not exist
[ 10.687402] : get_remote_sensor: video pad[0] is null
[ 10.687412] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 10.687425] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 10.687431] : get_remote_sensor: video pad[0] is null
[ 10.687440] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 10.687448] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 10.687454] : get_remote_sensor: video pad[0] is null
[ 10.687462] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 10.687471] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 10.687476] : get_remote_sensor: video pad[0] is null
[ 10.687484] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 10.687492] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 10.712156] rkcif rkcif-mipi-lvds: No memory-region-thunderboot specified
[ 10.713360] rockchip-mipi-csi2-hw ffa20000.mipi-csi2-hw: enter mipi csi2 hw probe!
[ 10.713514] rockchip-mipi-csi2-hw ffa20000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[ 10.713651] rockchip-mipi-csi2-hw ffa30000.mipi-csi2-hw: enter mipi csi2 hw probe!
[ 10.713762] rockchip-mipi-csi2-hw ffa30000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[ 10.714157] rockchip-mipi-csi2 mipi0-csi2: attach to csi2 hw node
[ 10.714220] rkcif rkcif-mipi-lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 10.714234] rockchip-mipi-csi2: Async registered subdev
[ 10.714251] rockchip-mipi-csi2: probe success, v4l2_dev:rkcif-mipi-lvds!
[ 10.785785] rkisp_hw ffa00000.rkisp: is_thunderboot: 0
[ 10.785800] rkisp_hw ffa00000.rkisp: Missing rockchip,grf property
[ 10.785841] rkisp_hw ffa00000.rkisp: max input:0x0@0fps
[ 10.786004] rkisp_hw ffa00000.rkisp: get sram size:253952
[ 10.786015] rkisp_hw ffa00000.rkisp: no iommu attached, using non-iommu buffers
[ 10.786024] rkisp_hw ffa00000.rkisp: No reserved memory region. default cma area!
[ 10.786388] rkisp rkisp-vir0: rkisp driver version: v02.05.00
[ 10.786498] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 10.792195] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 10.860979] rockchip-csi2-dphy-hw ff3e8000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 10.905280] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 11.531153] rk_gmac-dwmac ffa80000.ethernet eth0: PHY [stmmac-0:02] driver [RK630 PHY] (irq=POLL)
[ 11.531493] dwmac4: Master AXI performs any burst length
[ 11.531514] rk_gmac-dwmac ffa80000.ethernet eth0: No Safety Features support found
[ 11.531531] rk_gmac-dwmac ffa80000.ethernet eth0: PTP not supported by HW
[ 11.531849] rk_gmac-dwmac ffa80000.ethernet eth0: configuring for phy/rmii link mode
[ 11.631172] rkcif rkcif-mipi-lvds: clear unready subdev num: 2
[ 11.632535] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 11.632559] rkcif-mipi-lvds: Async subdev notifier completed
[ 11.632583] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 11.632594] rkcif-mipi-lvds: There is not terminal subdev, not synchronized with ISP
[ 11.632822] rkisp rkisp-vir0: clear unready subdev num: 1
[ 11.633134] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 11.633149] rkcif-mipi-lvds: There is not terminal subdev, not synchronized with ISP
[ 11.634190] rkisp-vir0: Async subdev notifier completed
[ 11.692514] rga: rga2, irq = 38, match scheduler
[ 11.696887] rga: rga2 hardware loaded successfully, hw_version:3.3.87975.
[ 11.696907] rga: rga2 probe successfully
[ 11.697201] rga_iommu: IOMMU binding successfully, default mapping core[0x4]
[ 11.698999] rga: Module initialized. v1.3.1
[ 11.731075] mpp_vcodec: loading out-of-tree module taints kernel.
[ 11.751066] mpp_vcodec: init new
[ 11.751205] mpp_service mpp-srv: 424abb9b author: Yandong Lin 2024-04-29 [mpp_enc]: fix wrap enc sw timeout when resolution switch
[ 11.751214] mpp_service mpp-srv: probe start
[ 11.765001] mpp_rkvenc_540c ffa50000.rkvenc: probing start
[ 11.765239] mpp_rkvenc_540c ffa50000.rkvenc: probing finish
[ 11.765752] mpp_vepu_pp ffa60000.rkvenc-pp: probe device
[ 11.765849] mpp_vepu_pp ffa60000.rkvenc-pp: shared_rst_a_pp is not found!
[ 11.765871] vepu_pp_init:526: No aclk reset resource define
[ 11.765882] mpp_vepu_pp ffa60000.rkvenc-pp: shared_rst_h_pp is not found!
[ 11.765890] vepu_pp_init:529: No hclk reset resource define
[ 11.774027] mpp_vepu_pp ffa60000.rkvenc-pp: probing finish
[ 11.774288] mpp_service mpp-srv: probe success
[ 11.804296] RKNPU ff660000.npu: RKNPU: rknpu iommu device-tree entry not found!, using non-iommu mode
[ 11.809522] RKNPU ff660000.npu: RKNPU: Initialized RKNPU driver: v0.9.2 for 20230825
[ 11.809624] RKNPU ff660000.npu: dev_pm_opp_set_regulators: no regulator (rknpu) found: -19
[ 11.882086] rockit_load start
[ 11.913714] rockit_load end
[ 11.948360] rve: rve_irq, irq = 55, match scheduler
[ 11.955074] rve: Driver loaded successfully rve[2] ver:[2021]58.1a
[ 11.955089] rve: probe successfully
[ 11.965565] rve: Module initialized. v1.0.6
[ 12.112258] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 12.112289] stream_cif_mipi_id1: update sensor info failed -19
[ 12.121309] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 12.121332] rkcif_scale_ch0: update sensor info failed -19
[ 12.138988] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 12.139012] stream_cif_mipi_id2: update sensor info failed -19
[ 12.142900] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 12.142924] rkcif_scale_ch1: update sensor info failed -19
[ 12.164446] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 12.164470] rkcif_scale_ch2: update sensor info failed -19
[ 12.170200] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 12.170223] rkcif_tools_id0: update sensor info failed -19
[ 12.192359] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 12.192381] stream_cif_mipi_id0: update sensor info failed -19
[ 12.200691] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 12.200713] stream_cif_mipi_id3: update sensor info failed -19
[ 12.207743] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 12.207766] rkcif_scale_ch3: update sensor info failed -19
[ 12.244376] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 12.244399] rkcif_tools_id1: update sensor info failed -19
[ 12.318880] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 12.318912] rkcif_tools_id2: update sensor info failed -19
[ 13.116809] file system registered
[ 13.174928] using random self ethernet address
[ 13.174943] using random host ethernet address
[ 13.445628] read descriptors
[ 13.445648] read strings
[ 14.411321] usb0: HOST MAC 72:76:d9:d6:ba:2a
[ 14.411332] usb0: MAC b2:ce:f9:c5:9b:f5
[ 14.591071] dwc3 ffb00000.usb: device reset
[ 14.646133] rk_gmac-dwmac ffa80000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 14.654296] android_work: sent uevent USB_STATE=CONNECTED
[ 14.702057] android_work: sent uevent USB_STATE=CONFIGURED
[ 18.011895] Alarm by: rockchip_rtc_alarm_irq
[ 18.158621] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2
[ 179.370785] systemd-journald[83]: File /var/log/journal/1fe5d22f36814c0598da7e315031b67d/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 179.390185] systemd-journald[83]: Failed to set ACL on /var/log/journal/1fe5d22f36814c0598da7e315031b67d/user-1000.journal, ignoring: Operation not supported
