Hello, I'm trying to compile SDK on distribution different than Ubuntu and I am getting following error:
source-cache.c:37:10: fatal error: srchilite/sourcehighlight.h: No such file or directory
The error refers to file
./sysdrv/tools/board/gdb/gdb-10.2/gdb/source-cache.c
I have source-highlight package installed in version 3.1.9-15 on my system, but decided to disable it anyway.
I edited file ./sysdrv/source/buildroot/buildroot-2023.02.6/package/gdb/gdb.mk and found that --disable-source-highlight is already present in GDB_CONF_OPTS and HOST_GDB_CONF_OPTS. Can you tell me what am I missing?
Edit: Adding option directly in Makefile solved the issue, but I am still curious why .mk file changes wouldn't apply
Error compiling SDK
Hello, in the SDK, in order to be able to use gdb when building the busybox image, the gdb compiled into the image and the gdb in the buildroot are not the same. The configuration in ./sysdrv/source/buildroot/buildroot-2023.02.6/package/gdb/gdb.mk will not affect the compilation of ./sysdrv/tools/board/gdb.
