Hi there,
I am running Ubuntu 22.04 on my Luckfox Pico Ultra W, but for some reason although USB is set to Host through luckfox-config, my USB Memory Stick is never recognized.
I am powering up my Ultra W through USB-C + 20W USB Power adapter.
Can someone suggest what might be issue?
Thanks!
USB Memory Stick not detected at Luckfox Pico Ultra W on Ubuntu 22.04 LTS
Hello, the CPU of Luckfox Pico Ultra (RV1106) only has one USB interface. When powered by USB-C, Luckfox Pico Ultra will automatically switch to USB-C. At this time, the USB-A interface cannot be used. You need to supply power to Luckfox Pico Ultra through pins or using PoE in order to use the USB-A interface.
Thank you for quick answer Crocodile.
What if I attach USB-C Hub to Pico Ultra W, which also has USB-C input for Power and couple of USB slots, will it work in that combination?
Something like this:
