I am working with a Luckfox Pico Ultra W board (RV1106) running a Buildroot system.
I've noticed a consistently very high load average (e.g., Load average: 10.24 10.10 10.11) when I check using the top command, even when no specific user applications are running (i.e., the system is mostly idle). At the same time, top shows a high CPU idle percentage (around 85-95%), with low user and system CPU usage.
Mem: 161076K used, 14140K free, 880K shrd, 7808K buff, 127000K cached
CPU: 1% usr 3% sys 0% nic 95% idle 0% io 0% irq 0% sirq
Load average: 10.04 10.06 10.08 1/97 343
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
3755 2529 root R 1800 1% 0% top
2519 311 root S 5276 3% 0% sshd: root@pts/1
431 2 root SW 0 0% 0% [irq/67-dwc3]
272 2 root DW 0 0% 0% [vmcu]
574 1 root S 33016 19% 0% smbd -D
577 574 root S 32088 18% 0% {smbd-notifyd} smbd -D
578 574 root S 32080 18% 0% {smbd-cleanupd} smbd -D
629 1 root S 24604 14% 0% nmbd -D
415 1 root S 10220 6% 0% /usr/bin/adbd
460 1 root S 5192 3% 0% rkwifi_server start
311 1 root S 4964 3% 0% sshd: /usr/sbin/sshd [listener] 0 of 10-100 startups
183 1 root S 4928 3% 0% /usr/libexec/bluetooth/bluetoothd -n
2529 2519 root S 1828 1% 0% -sh
177 1 dbus S 1812 1% 0% dbus-daemon --system
1333 1 root S 1804 1% 0% {S99usb0config} /bin/sh /etc/init.d/S99usb0config start
1 0 root S 1796 1% 0% init
1334 1 root S 1792 1% 0% /sbin/getty -L console 0 vt100
86 1 root S 1788 1% 0% /sbin/syslogd -n
325 1 root S 1788 1% 0% /usr/sbin/telnetd -F
90 1 root S 1784 1% 0% /sbin/klogd -n
101 1 root S 1424 1% 0% /sbin/udevd -d
565 1 root S 1248 1% 0% wpa_supplicant -B -i wlan0 -c /data/wpa_supplicant.conf -d
643 1 root S 956 1% 0% hciattach -s 1500000 /dev/ttyS1 any 1500000 flow nosleep
1314 1 root S 768 0% 0% luckfox_switch_rgb_resolution
254 2 root SW 0 0% 0% [vcodec_thread_0]
250 2 root SW 0 0% 0% [queue_work0]
7 2 root SW 0 0% 0% [ksoftirqd/0]
3341 2 root IW< 0 0% 0% [kworker/0:0H-kb]
11 2 root SW 0 0% 0% [kcompactd0]
48 2 root SW 0 0% 0% [kswapd0]
268 2 root DW 0 0% 0% [rkisp-vir0]
4065 2 root IW 0 0% 0% [kworker/0:1-eve]
40 2 root SW 0 0% 0% [kconsole]
425 2 root SW 0 0% 0% [aicwf_busrx_thr]
267 2 root DW 0 0% 0% [venc]
423 2 root SW 0 0% 0% [aicwf_pwrctl]
252 2 root SW 0 0% 0% [queue_work1]
468 2 root IW 0 0% 0% [kworker/u2:2-ev]
253 2 root SW 0 0% 0% [irq/50-ffa60000]
67 2 root SW 0 0% 0% [jbd2/mmcblk0p7-]
151 2 root SW 0 0% 0% [jbd2/mmcblk0p5-]
117 2 root IW< 0 0% 0% [kworker/0:3H-kb]
56 2 root IW< 0 0% 0% [stmmac_wq]
175 2 root SW 0 0% 0% [irq/51-ffa70000]
45 2 root IW< 0 0% 0% [kworker/u3:0-hc]
My questions are:
1. Is such a high load average (around 10) with high CPU idle considered normal or expected for this board with a standard Buildroot configuration?
2. If this is not normal, what could be the common causes for this behavior on the RV1106 platform (e.g., I/O wait issues, specific kernel tasks, driver problems, default services)?
3. Are there any recommended diagnostic tools or steps specific to the Luckfox Pico Ultra W / RV1106 to investigate this high idle load average further?
Any insights or suggestions would be greatly appreciated!
Thanks,
