Running Luckfox Pico Ultra W against IMX415 8MP at 8M@10fps
Posted: 2025-12-24 14:01
by arier
is it possible to configure Luckfox Pico Ultra W to work against IMX415 8MP at 8M@10fps or 8M@5fps?
And if yes, where and how I configure that?
Kind regards,
Arie
Re: Running Luckfox Pico Ultra W against IMX415 8MP at 8M@10fps
Posted: 2025-12-25 1:39
by yangxj121
The attached file contains the maximum supported values for the 1106 data manual. Theoretically, it can support 8m at 15fps. When you use it, for example, when using v4l2-ctl, you can adjust the resolution parameters to achieve the desired result.
