luckfox_pico_pro 在Ubuntu22.04 环境下,使用.build.sh生成镜像,将镜像文件下载到开发板,开发板一直重启。
反复执行一下内容:
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.110 (root@lv) (arm-rockchip830-linux-uclibcgnueabihf-gcc (crosstool-NG 1.24.0) 8.3.0, GNU ld (crosstool-NG 1.24.0) 2.32) #1 Sun Apr 21 15:48:46 CST 2024
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c53c7d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Luckfox Pico Max
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 67584 KiB at 0x03e00000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: user_debug=31 storagemedia=mtd androidboot.storagemedia=mtd androidboot.mode=normal rootwait earlycon=uart8250,mmio32,0xff4c0000 console=ttyFIQ0 snd_soc_core.prealloc_buffer_size_kbytes=16 coherent_pool=0 ubi.mtd=6 root=ubi0:rootfs rootfstype=ubifs rk_dma_heap_cma=66M mtdparts=spi-nand0:256K(env),256K@256K(idblock),512K(uboot),4M(boot),30M(oem),10M(userdata),210M(rootfs)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 56124K/131072K available (3543K kernel code, 292K rwdata, 1680K rodata, 164K init, 132K bss, 7364K reserved, 67584K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x1fb/0x360 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000017] Switching to timer-based delay loop, resolution 41ns
[ 0.000332] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.000349] pid_max: default: 4096 minimum: 301
[ 0.000492] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000504] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001036] CPU: Testing write buffer coherency: ok
[ 0.001434] Setting up static identity map for 0x81c0 - 0x81f8
[ 0.001790] devtmpfs: initialized
[ 0.007787] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.007942] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.007960] futex hash table entries: 16 (order: -5, 192 bytes, linear)
[ 0.008042] pinctrl core: initialized pinctrl subsystem
[ 0.008719] NET: Registered protocol family 16
[ 0.009010] DMA: failed to allocate 0 KiB pool for atomic coherent allocation
[ 0.009666] thermal_sys: Registered thermal governor 'step_wise'
[ 0.009672] thermal_sys: Registered thermal governor 'user_space'
[ 0.009940] cpuidle: using governor menu
[ 0.009972] Registered FIQ tty driver
[ 0.023056] rockchip-gpio ff380000.gpio: probed /pinctrl/gpio@ff380000
[ 0.023837] rockchip-gpio ff530000.gpio: probed /pinctrl/gpio@ff530000
[ 0.024409] rockchip-gpio ff540000.gpio: probed /pinctrl/gpio@ff540000
[ 0.025040] rockchip-gpio ff550000.gpio: probed /pinctrl/gpio@ff550000
[ 0.025608] rockchip-gpio ff560000.gpio: probed /pinctrl/gpio@ff560000
[ 0.025686] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.032366] fiq_debugger fiq_debugger.0: IRQ uart_irq not found
[ 0.032390] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 0.032631] printk: console [ttyFIQ0] enabled
[ 0.032787] Registered fiq debugger ttyFIQ0
[ 0.034564] usbcore: registered new interface driver usbfs
[ 0.034620] usbcore: registered new interface driver hub
[ 0.034664] usbcore: registered new device driver usb
[ 0.034869] mc: Linux media interface: v0.10
[ 0.034908] videodev: Linux video capture interface: v2.00
[ 0.035859] Advanced Linux Sound Architecture Driver Initialized.
[ 0.036510] rockchip-cpuinfo cpuinfo: SoC : 11061000
[ 0.036529] rockchip-cpuinfo cpuinfo: Serial : e6a47f5f83ada96c
[ 0.036908] rockchip,rknpor-powergood ff000000.syscon:rknpor-powergood: probe success!
[ 0.037513] clocksource: Switched to clocksource arch_sys_counter
[ 0.038600] NET: Registered protocol family 2
[ 0.038748] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.039207] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.039257] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.039277] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.039292] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.039384] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.039416] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.039510] NET: Registered protocol family 1
[ 0.039892] RPC: Registered named UNIX socket transport module.
[ 0.039909] RPC: Registered udp transport module.
[ 0.039916] RPC: Registered tcp transport module.
[ 0.039923] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.040877] Initialise system trusted keyrings
[ 0.041073] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.044619] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.045299] NFS: Registering the id_resolver key type
[ 0.045346] Key type id_resolver registered
[ 0.045371] Key type id_legacy registered
[ 0.045415] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[ 0.045801] Key type asymmetric registered
[ 0.045838] Asymmetric key parser 'x509' registered
[ 0.045861] io scheduler mq-deadline registered
[ 0.046100] rockchip-usb2phy ff3e0000.usb2-phy: IRQ index 0 not found
[ 0.051846] dma-pl330 ff420000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.051871] dma-pl330 ff420000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.052542] rockchip-pvtm ff240000.pvtm: pvtm@0 probed
[ 0.052745] rockchip-pvtm ff390000.pvtm: pvtm@0 probed
[ 0.053271] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.053900] ff4d0000.serial: ttyS3 at MMIO 0xff4d0000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.054669] ff4e0000.serial: ttyS4 at MMIO 0xff4e0000 (irq = 39, base_baud = 1500000) is a 16550A
[ 0.059544] random: fast init done
[ 0.059663] random: crng init done
[ 0.068745] brd: module loaded
[ 0.074098] loop: module loaded
[ 0.075303] rockchip-spi ff500000.spi: no high_speed pinctrl state
[ 0.077546] spi-nand spi2.0: Winbond SPI NAND was found.
[ 0.077574] spi-nand spi2.0: 256 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
[ 0.078662] 7 cmdlinepart partitions found on MTD device spi-nand0
[ 0.078674] Creating 7 MTD partitions on "spi-nand0":
[ 0.078690] 0x000000000000-0x000000040000 : "env"
[ 0.080367] 0x000000040000-0x000000080000 : "idblock"
[ 0.082012] 0x000000080000-0x000000100000 : "uboot"
[ 0.083594] 0x000000100000-0x000000500000 : "boot"
[ 0.085256] 0x000000500000-0x000002300000 : "oem"
[ 0.086960] 0x000002300000-0x000002d00000 : "userdata"
[ 0.088596] 0x000002d00000-0x00000ff00000 : "rootfs"
[ 0.092179] rk_gmac-dwmac ffa80000.ethernet: IRQ eth_lpi not found
[ 0.092322] rk_gmac-dwmac ffa80000.ethernet: PTP uses main clock
[ 0.092362] rk_gmac-dwmac ffa80000.ethernet: no regulator found
[ 0.092375] rk_gmac-dwmac ffa80000.ethernet: clock input or output? (input).
[ 0.092384] rk_gmac-dwmac ffa80000.ethernet: Can not read property: tx_delay.
[ 0.092393] rk_gmac-dwmac ffa80000.ethernet: set tx_delay to 0xffffffff
[ 0.092402] rk_gmac-dwmac ffa80000.ethernet: Can not read property: rx_delay.
[ 0.092410] rk_gmac-dwmac ffa80000.ethernet: set rx_delay to 0xffffffff
[ 0.092479] rk_gmac-dwmac ffa80000.ethernet: integrated PHY? (yes).
[ 0.092495] rk_gmac-dwmac ffa80000.ethernet: cannot get clock mac_clk_rx
[ 0.092506] rk_gmac-dwmac ffa80000.ethernet: cannot get clock mac_clk_tx
[ 0.092532] rk_gmac-dwmac ffa80000.ethernet: cannot get clock clk_mac_speed
[ 0.092540] rk_gmac-dwmac ffa80000.ethernet: clock input from PHY
[ 0.092784] rk_gmac-dwmac ffa80000.ethernet: init for RMII
[ 0.092975] rk_gmac-dwmac ffa80000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.092996] rk_gmac-dwmac ffa80000.ethernet: DWMAC4/5
[ 0.093008] rk_gmac-dwmac ffa80000.ethernet: DMA HW capability register supported
[ 0.093016] rk_gmac-dwmac ffa80000.ethernet: RX Checksum Offload Engine supported
[ 0.093023] rk_gmac-dwmac ffa80000.ethernet: TX Checksum insertion supported
[ 0.093032] rk_gmac-dwmac ffa80000.ethernet: Wake-Up On Lan supported
[ 0.093038] rk_gmac-dwmac ffa80000.ethernet: TSO supported
[ 0.093054] rk_gmac-dwmac ffa80000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.093062] rk_gmac-dwmac ffa80000.ethernet: TSO feature enabled
[ 0.093072] rk_gmac-dwmac ffa80000.ethernet: Using 40 bits DMA width
[ 0.101619] rockchip-rtc ff1c0000.rtc: rockchip_rtc_compensation:timeout waiting for RTC TEST STATUS : -110
[ 0.102344] rockchip-rtc ff1c0000.rtc: registered as rtc0
[ 0.102431] rockchip-rtc ff1c0000.rtc: setting system clock to 2021-01-03T12:06:03 UTC (1609675563)
[ 0.102677] i2c /dev entries driver
[ 0.104441] i2c i2c-4: 1 i2c clients have been registered at 0x30
[ 0.104810] i2c i2c-4: 2 i2c clients have been registered at 0x30
[ 0.106774] rockchip-thermal ff3c8000.tsadc: tsadc is probed successfully!
[ 0.107267] cpu cpu0: Failed to get cpu_leakage
[ 0.108394] cpu cpu0: avs=0
[ 0.109065] cpu cpu0: rockchip_pvtpll_set_volt: failed to set vdd voltage (925000 1050000 uV): -22
[ 0.109218] cpu cpu0: failed to register system monitor
[ 0.109647] Synopsys Designware Multimedia Card Interface Driver
[ 0.110537] dwmmc_rockchip ffaa0000.mmc: IDMAC supports 32-bit address mode.
[ 0.110581] dwmmc_rockchip ffaa0000.mmc: Using internal DMA controller.
[ 0.110595] dwmmc_rockchip ffaa0000.mmc: Version ID is 270a
[ 0.110634] dwmmc_rockchip ffaa0000.mmc: DW MMC controller at irq 54,32 bit host data width,256 deep fifo
[ 0.113716] rv1106-acodec ff480000.acodec: current soc_id: rv1106
[ 0.113809] rv1106-acodec ff480000.acodec: Use pa_ctl_gpio and pa_ctl_delay_ms: 0
[ 0.115583] NET: Registered protocol family 17
[ 0.115694] Key type dns_resolver registered
[ 0.116456] Loading compiled-in X.509 certificates
[ 0.117034]
[ 0.117052] ********************************************************************
[ 0.117062] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.117069] ** **
[ 0.117074] ** WRITEABLE clk DebugFS SUPPORT HAS BEEN ENABLED IN THIS KERNEL **
[ 0.117080] ** **
[ 0.117086] ** This means that this kernel is built to expose clk operations **
[ 0.117091] ** such as parent or rate setting, enabling, disabling, etc. **
[ 0.117097] ** to userspace, which may compromise security on your system. **
[ 0.117102] ** **
[ 0.117108] ** If you see this message and you are not debugging the **
[ 0.117113] ** kernel, report this immediately to your vendor! **
[ 0.117118] ** **
[ 0.117123] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.117128] ********************************************************************
[ 0.121153] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.134585] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 0.202421] ubi0: attaching mtd6
[ 0.601848] ubi0: scanning is finished
[ 0.607386] ubi0: attached mtd6 (name "rootfs", size 210 MiB)
[ 0.607408] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 0.607416] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 0.607425] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 0.607433] ubi0: good PEBs: 1680, bad PEBs: 0, corrupted PEBs: 0
[ 0.607441] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 0.607450] ubi0: max/mean erase counter: 4/1, WL threshold: 4096, image sequence number: 1250908435
[ 0.607459] ubi0: available PEBs: 0, total reserved PEBs: 1680, PEBs reserved for bad PEB handling: 40
[ 0.608346] ALSA device list:
[ 0.608388] #0: rv-acodec
[ 0.608880] ubi0: background thread "ubi_bgt0d" started, PID 57
[ 0.609133] UBIFS (ubi0:0): Mounting in unauthenticated mode
[ 0.637596] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs", R/O mode
[ 0.637622] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 0.637634] UBIFS (ubi0:0): FS size: 206336000 bytes (196 MiB, 1625 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 0.637644] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
[ 0.637654] UBIFS (ubi0:0): media format: w4/r0 (latest is w5/r0), UUID 438D7B93-BD61-4062-B806-5DB1BB9213AB, small LPT model
[ 0.638810] VFS: Mounted root (ubifs filesystem) readonly on device 0:14.
[ 0.639597] devtmpfs: mounted
[ 0.639785] Freeing unused kernel memory: 164K
[ 0.639796] Kernel memory protection not selected by kernel config.
[ 0.639829] Run /sbin/init as init process
[ 0.646711] process '/bin/busybox' started with executable stack
[ 0.711636] UBIFS (ubi0:0): start fixing up free space
DDR V1.10 ec2fae0c96 wesley.yao 22/11/15-10:58:09
S5P1
f947
rgef1
DDRConf2
DDR3, BW=16 Col=10 Bk=8 CS0 Row=13 CS=1 Die BW=16 Size=128MB
924MHz
DDR bin out
U-Boot SPL board init
U-Boot SPL 2017.09 (Apr 21 2024 - 19:41:28)
unrecognized JEDEC id bytes: ff, ef, aa
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 2
spl: mmc init failed with error: -123
Trying to boot from MTD1
ENVF: Primary 0x00000000 - 0x00040000
ENVF: OK
Trying fit image at 0x400 sector
## Verified-boot: 0
## Checking uboot 0x00200000 (lzma @0x00400000) ... sha256(9ebb9d333e...) +
sha256(6bdb3d1c3e...) + OK
## Checking fdt 0x0025bfd8 ... sha256(51bba657c3...) + OK
Total: 223.211 ms
Jumping to U-Boot(0x00200000)
U-Boot 2017.09 (Apr 21 2024 - 19:41:28 +0800)
Model: Rockchip RV1106 EVB Board
PreSerial: 2, raw, 0xff4c0000
DRAM: 128 MiB
Sysmem: init
Relocation Offset: 07d85000
Relocation fdt: 06dfadb0 - 06dfedd8
CR: M/C/I
Using default environment
Bootdev(atags): mtd 1
ENVF: OK
PartType: ENV
DM: v2
No misc partition
boot mode: None
FIT: no signed, no conf required
DTB: rk-kernel.dtb
HASH(c): OK
Model: Luckfox Pico Max
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 816000 KHz
dpll 924000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
aclk_peri_root 400000 KHz
hclK_peri_root 200000 KHz
pclk_peri_root 100000 KHz
aclk_bus_root 300000 KHz
pclk_top_root 100000 KHz
pclk_pmu_root 100000 KHz
hclk_pmu_root 200000 KHz
Net:
eth0: ethernet@ffa80000
Hit key to stop autoboot('CTRL+C'): 0
## Booting FIT Image
at 0x6940780 with size 0x002b9600
Fdt Ramdisk skip relocation
No misc partition
## Loading kernel from FIT Image at 06940780 ...
Using 'conf' configuration
## Verified-boot: 0
Trying 'kernel' kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0x06949780
Data Size: 2819336 Bytes = 2.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: sha256
Hash value: 0a7c5ba3811905ebbabccb48a06e75a967ba6330c4be0e985f56056869c83ac2
Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 06940780 ...
Trying 'fdt' fdt subimage
Type: Flat Device Tree
Data Start: 0x06940f80
Data Size: 34709 Bytes = 33.9 KiB
Architecture: ARM
Load Address: 0x00c00000
Hash algo: sha256
Hash value: 9e4b26473894c041e9179149bf81dd16c0e84f27f17ac53fbdfa601bd32eaac0
Loading fdt from 0x00c00000 to 0x00c00000
Booting using the fdt blob at 0x00c00000
Loading Kernel Image from 0x06949780 to 0x00008000 ... OK
kernel loaded at 0x00008000, end = 0x002b8508
Using Device Tree in place at 00c00000, end 00c0b794
Adding bank: 0x00000000 - 0x08000000 (size: 0x08000000)
Total: 522.607 ms
Starting kernel ...
[ 0.000331] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.000496] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000511] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001045] CPU: Testing write buffer coherency: ok
[ 0.001453] Setting up static identity map for 0x81c0 - 0x81f8
[ 0.001820] devtmpfs: initialized
[ 0.007799] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.007958] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.007977] futex hash table entries: 16 (order: -5, 192 bytes, linear)
[ 0.008056] pinctrl core: initialized pinctrl subsystem
[ 0.008730] NET: Registered protocol family 16
[ 0.009021] DMA: failed to allocate 0 KiB pool for atomic coherent allocation
[ 0.009667] thermal_sys: Registered thermal governor 'step_wise'
[ 0.009673] thermal_sys: Registered thermal governor 'user_space'
[ 0.009934] cpuidle: using governor menu
[ 0.009965] Registered FIQ tty driver
[ 0.023026] rockchip-gpio ff380000.gpio: probed /pinctrl/gpio@ff380000
[ 0.023793] rockchip-gpio ff530000.gpio: probed /pinctrl/gpio@ff530000
[ 0.024357] rockchip-gpio ff540000.gpio: probed /pinctrl/gpio@ff540000
[ 0.024982] rockchip-gpio ff550000.gpio: probed /pinctrl/gpio@ff550000
[ 0.025568] rockchip-gpio ff560000.gpio: probed /pinctrl/gpio@ff560000
[ 0.025646] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.032281] fiq_debugger fiq_debugger.0: IRQ uart_irq not found
[ 0.032303] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 0.032538] printk: console [ttyFIQ0] enabled
[ 0.032691] Registered fiq debugger ttyFIQ0
[ 0.034484] usbcore: registered new interface driver usbfs
[ 0.034536] usbcore: registered new interface driver hub
[ 0.034581] usbcore: registered new device driver usb
[ 0.034779] mc: Linux media interface: v0.10
[ 0.034817] videodev: Linux video capture interface: v2.00
[ 0.035772] Advanced Linux Sound Architecture Driver Initialized.
[ 0.036429] rockchip-cpuinfo cpuinfo: SoC : 11061000
[ 0.036449] rockchip-cpuinfo cpuinfo: Serial : e6a47f5f83ada96c
[ 0.036812] rockchip,rknpor-powergood ff000000.syscon:rknpor-powergood: probe success!
[ 0.037410] clocksource: Switched to clocksource arch_sys_counter
[ 0.038496] NET: Registered protocol family 2
[ 0.038644] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.039107] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.039158] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.039180] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.039195] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.039286] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.039318] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.039416] NET: Registered protocol family 1
[ 0.039797] RPC: Registered named UNIX socket transport module.
[ 0.039813] RPC: Registered udp transport module.
[ 0.039820] RPC: Registered tcp transport module.
[ 0.039825] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.040784] Initialise system trusted keyrings
[ 0.040987] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.044555] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.045225] NFS: Registering the id_resolver key type
[ 0.045290] Key type id_resolver registered
[ 0.045307] Key type id_legacy registered
[ 0.045350] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[ 0.045759] Key type asymmetric registered
[ 0.045782] Asymmetric key parser 'x509' registered
[ 0.045804] io scheduler mq-deadline registered
[ 0.046042] rockchip-usb2phy ff3e0000.usb2-phy: IRQ index 0 not found
[ 0.051782] dma-pl330 ff420000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.051808] dma-pl330 ff420000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.052493] rockchip-pvtm ff240000.pvtm: pvtm@0 probed
[ 0.052694] rockchip-pvtm ff390000.pvtm: pvtm@0 probed
[ 0.053219] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.053850] ff4d0000.serial: ttyS3 at MMIO 0xff4d0000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.054624] ff4e0000.serial: ttyS4 at MMIO 0xff4e0000 (irq = 39, base_baud = 1500000) is a 16550A
[ 0.059496] random: fast init done
[ 0.059618] random: crng init done
[ 0.068790] brd: module loaded
[ 0.074241] loop: module loaded
[ 0.075401] rockchip-spi ff500000.spi: no high_speed pinctrl state
[ 0.077644] spi-nand spi2.0: Winbond SPI NAND was found.
[ 0.077668] spi-nand spi2.0: 256 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
[ 0.078756] 7 cmdlinepart partitions found on MTD device spi-nand0
[ 0.078770] Creating 7 MTD partitions on "spi-nand0":
[ 0.078787] 0x000000000000-0x000000040000 : "env"
[ 0.080433] 0x000000040000-0x000000080000 : "idblock"
[ 0.082082] 0x000000080000-0x000000100000 : "uboot"
[ 0.083669] 0x000000100000-0x000000500000 : "boot"
[ 0.085359] 0x000000500000-0x000002300000 : "oem"
[ 0.087081] 0x000002300000-0x000002d00000 : "userdata"
[ 0.088715] 0x000002d00000-0x00000ff00000 : "rootfs"
[ 0.092294] rk_gmac-dwmac ffa80000.ethernet: IRQ eth_lpi not found
[ 0.092440] rk_gmac-dwmac ffa80000.ethernet: PTP uses main clock
[ 0.092479] rk_gmac-dwmac ffa80000.ethernet: no regulator found
[ 0.092491] rk_gmac-dwmac ffa80000.ethernet: clock input or output? (input).
[ 0.092500] rk_gmac-dwmac ffa80000.ethernet: Can not read property: tx_delay.
[ 0.092509] rk_gmac-dwmac ffa80000.ethernet: set tx_delay to 0xffffffff
[ 0.092518] rk_gmac-dwmac ffa80000.ethernet: Can not read property: rx_delay.
[ 0.092526] rk_gmac-dwmac ffa80000.ethernet: set rx_delay to 0xffffffff
[ 0.092595] rk_gmac-dwmac ffa80000.ethernet: integrated PHY? (yes).
[ 0.092611] rk_gmac-dwmac ffa80000.ethernet: cannot get clock mac_clk_rx
[ 0.092621] rk_gmac-dwmac ffa80000.ethernet: cannot get clock mac_clk_tx
[ 0.092648] rk_gmac-dwmac ffa80000.ethernet: cannot get clock clk_mac_speed
[ 0.092658] rk_gmac-dwmac ffa80000.ethernet: clock input from PHY
[ 0.092901] rk_gmac-dwmac ffa80000.ethernet: init for RMII
[ 0.093091] rk_gmac-dwmac ffa80000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.093112] rk_gmac-dwmac ffa80000.ethernet: DWMAC4/5
[ 0.093125] rk_gmac-dwmac ffa80000.ethernet: DMA HW capability register supported
[ 0.093134] rk_gmac-dwmac ffa80000.ethernet: RX Checksum Offload Engine supported
[ 0.093141] rk_gmac-dwmac ffa80000.ethernet: TX Checksum insertion supported
[ 0.093148] rk_gmac-dwmac ffa80000.ethernet: Wake-Up On Lan supported
[ 0.093164] rk_gmac-dwmac ffa80000.ethernet: TSO supported
[ 0.093171] rk_gmac-dwmac ffa80000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.093178] rk_gmac-dwmac ffa80000.ethernet: TSO feature enabled
[ 0.093188] rk_gmac-dwmac ffa80000.ethernet: Using 40 bits DMA width
[ 0.101742] rockchip-rtc ff1c0000.rtc: rockchip_rtc_compensation:timeout waiting for RTC TEST STATUS : -110
[ 0.102469] rockchip-rtc ff1c0000.rtc: registered as rtc0
[ 0.102549] rockchip-rtc ff1c0000.rtc: setting system clock to 2021-01-03T12:06:11 UTC (1609675571)
[ 0.102785] i2c /dev entries driver
[ 0.104539] i2c i2c-4: 1 i2c clients have been registered at 0x30
[ 0.104915] i2c i2c-4: 2 i2c clients have been registered at 0x30
[ 0.106893] rockchip-thermal ff3c8000.tsadc: tsadc is probed successfully!
[ 0.107384] cpu cpu0: Failed to get cpu_leakage
[ 0.108481] cpu cpu0: avs=0
[ 0.109159] cpu cpu0: rockchip_pvtpll_set_volt: failed to set vdd voltage (925000 1050000 uV): -22
[ 0.109324] cpu cpu0: failed to register system monitor
[ 0.109732] Synopsys Designware Multimedia Card Interface Driver
[ 0.110607] dwmmc_rockchip ffaa0000.mmc: IDMAC supports 32-bit address mode.
[ 0.110651] dwmmc_rockchip ffaa0000.mmc: Using internal DMA controller.
[ 0.110667] dwmmc_rockchip ffaa0000.mmc: Version ID is 270a
[ 0.110708] dwmmc_rockchip ffaa0000.mmc: DW MMC controller at irq 54,32 bit host data width,256 deep fifo
[ 0.113789] rv1106-acodec ff480000.acodec: current soc_id: rv1106
[ 0.113880] rv1106-acodec ff480000.acodec: Use pa_ctl_gpio and pa_ctl_delay_ms: 0
[ 0.115633] NET: Registered protocol family 17
[ 0.115745] Key type dns_resolver registered
[ 0.116505] Loading compiled-in X.509 certificates
[ 0.117061]
[ 0.117079] ********************************************************************
[ 0.117089] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.117095] ** **
[ 0.117101] ** WRITEABLE clk DebugFS SUPPORT HAS BEEN ENABLED IN THIS KERNEL **
[ 0.117107] ** **
[ 0.117113] ** This means that this kernel is built to expose clk operations **
[ 0.117119] ** such as parent or rate setting, enabling, disabling, etc. **
[ 0.117124] ** to userspace, which may compromise security on your system. **
[ 0.117129] ** **
[ 0.117135] ** If you see this message and you are not debugging the **
[ 0.117140] ** kernel, report this immediately to your vendor! **
[ 0.117145] ** **
[ 0.117150] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.117155] ********************************************************************
[ 0.121216] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.134532] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 0.202318] ubi0: attaching mtd6
[ 0.593798] ubi0: scanning is finished
[ 0.599305] ubi0: attached mtd6 (name "rootfs", size 210 MiB)
[ 0.599327] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 0.599335] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 0.599344] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 0.599351] ubi0: good PEBs: 1680, bad PEBs: 0, corrupted PEBs: 0
[ 0.599360] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 0.599369] ubi0: max/mean erase counter: 4/1, WL threshold: 4096, image sequence number: 1250908435
[ 0.599378] ubi0: available PEBs: 0, total reserved PEBs: 1680, PEBs reserved for bad PEB handling: 40
[ 0.600243] ALSA device list:
[ 0.600287] #0: rv-acodec
[ 0.600799] ubi0: background thread "ubi_bgt0d" started, PID 57
[ 0.601045] UBIFS (ubi0:0): Mounting in unauthenticated mode
[ 0.625874] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs", R/O mode
[ 0.625900] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 0.625913] UBIFS (ubi0:0): FS size: 206336000 bytes (196 MiB, 1625 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 0.625922] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
[ 0.625933] UBIFS (ubi0:0): media format: w4/r0 (latest is w5/r0), UUID 438D7B93-BD61-4062-B806-5DB1BB9213AB, small LPT model
[ 0.627074] VFS: Mounted root (ubifs filesystem) readonly on device 0:14.
[ 0.627868] devtmpfs: mounted
[ 0.628054] Freeing unused kernel memory: 164K
[ 0.628063] Kernel memory protection not selected by kernel config.
[ 0.628095] Run /sbin/init as init process
[ 0.634959] process '/bin/busybox' started with executable stack
[ 0.699523] UBIFS (ubi0:0): start fixing up free space
S5P1
f947
rgef1
DDRConf2
924MHz
DDR bin out
ENVF: OK
## Verified-boot: 0
Total: 223.259 ms
DRAM: 128 MiB
Sysmem: init
CR: M/C/I
ENVF: OK
PartType: ENV
DM: v2
No misc partition
boot mode: None
DTB: rk-kernel.dtb
HASH(c): OK
apll 816000 KHz
dpll 924000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
Net:
No misc partition
## Verified-boot: 0
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: sha256
Architecture: ARM
Hash algo: sha256
Total: 522.75 ms
BoardConfig-SPI_NAND-Buildroot-RV1106_Luckfox_Pico_Pro_Max-IPC.mk 编译后一直重启
您好,请尝试使用网盘镜像烧录测试是否能正常进入系统,出现一直重启的原因有多种,比较常见的就是开启多个默认的应用占用内存过大或者应用发生错误导致。但是根据您的内核打印信息,每一次重启都是在执行 "UBIFS (ubi0:0): start fixing up free space" 后的,很可能是在执行/etc/init.d/S20linkmount 时分配相应的存储空间时发生错误导致,建议使用网盘系统的原因就是先排除掉硬件上的问题。
