I just got a Luckfox Pico Mini B
I boots and I can login using ssh, but when I connect the SC3336 camera and plug it the PC USB the Pico does not boot.
Thanks
Luckfox Pico Mini B does not boot with SC3336 camera connected
Hello, please check if the ribbon cable is inserted in the correct direction. If it is inserted incorrectly, the Luckfox-pico will not function properly.
Thanks for your response. I will reinstall and check the ribbon cable latter and will let you know the results.
Hello, I solved the issue by re-flashing the SD card.
Thanks
Thanks
