luckfox-pico正常插接pico-lcd-1.3,运行lvgl_demo中的demo,屏幕无显示
将所有修改的配置文件上传,请帮忙看看错在哪里?谢谢!
文件1:rv1103g-luckfox-pico.dts
#include "rv1103.dtsi"
#include "rv1106-evb.dtsi"
#include "rv1103-luckfox-pico-ipc.dtsi"
model = "Luckfox Pico";
compatible = "rockchip,rv1103g-38x38-ipc-v10", "rockchip,rv1103";
gpio1pc7:gpio1pc7 {
compatible = "regulator-fixed";
pinctrl-names = "default";
pinctrl-0 = <&gpio1_pc7>;
regulator-name = "gpio1_pc7";
regulator-always-on;
gpio1pc0:gpio1pc0 {
pinctrl-0 = <&gpio1_pc0>;
regulator-name = "gpio1_pc0";
gpio1pa2:gpio1pa2 {
pinctrl-0 = <&gpio1_pa2>;
regulator-name = "gpio1_pa2";
gpio1pc3:gpio1pc3 {
pinctrl-0 = <&gpio1_pc3>;
regulator-name = "gpio1_pc3";
gpio0pa4:gpio0pa4 {
pinctrl-0 = <&gpio0_pa4>;
regulator-name = "gpio0_pa4";
/**********SDMMC**********/
&sdmmc {
max-frequency = <50000000>;
no-sdio;
no-mmc;
bus-width = <4>;
cap-mmc-highspeed;
cap-sd-highspeed;
disable-wp;
pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_det &sdmmc0_bus4>;
&pinctrl {
gpio1-pc7 {
gpio1_pc7:gpio1-pc7 {
rockchip,pins = <1 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>;
gpio1-pc0 {
gpio1_pc0:gpio1-pc0 {
rockchip,pins = <1 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>;
gpio1-pa2 {
gpio1_pa2:gpio1-pa2 {
rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
gpio1-pc3 {
gpio1_pc3:gpio1-pc3 {
rockchip,pins = <1 RK_PC3 RK_FUNC_GPIO &pcfg_pull_none>;
gpio0-pa4 {
gpio0_pa4:gpio0-pa4 {
rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
/**********ETH**********/
&gmac {
status = "disabled";
/**********USB**********/
&usbdrd_dwc3 {
dr_mode = "peripheral";
/**********I2C**********/
/* I2C3_M1 */
&i2c3 {
clock-frequency = <100000>;
/**********SPI**********/
&spi0 {
pinctrl-0 = <&spi0m0_cs0 &spi0m0_pins>;
spidev@0 {
st7789v@0{
compatible = "sitronix,st7789v";
reg = <0>;
spi-max-frequency = <20000000>;//20000000
fps = <30>;
buswidth = <8>;
debug = <0x7>;
led-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>;//BL
dc = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>; //DC
reset = <&gpio1 RK_PC3 GPIO_ACTIVE_LOW>; //RES
文件二:luckfox_rv1106_linux_defconfig 增加
CONFIG_SPI_MASTER=y
CONFIG_FB=y
现象:在dev中没有生成fb0,sys/class/gpio里没有生成配置过的GPIO
luckfox-pico 不能点亮pico-lcd-1.3
这个问题在之前的帖子中已经回答过了,烧录最新的系统就可以支持FBTFT了。还有就是我们不同版本的SDK对应的设备树内容也是有出入的。
http://forums.luckfox.com/viewtopic.php?p=2560#p2560
http://forums.luckfox.com/viewtopic.php?t=887
