Need help debugging with GDB+gdbserver
Can someone provide a detailed guide to debugging RV 1106 using GDB+gdbserver?
When conducting remote debugging on the Luckfox Pico using GDB and gdbserver, ensure that you have set it up following the steps below:
1. Launch gdbserver on Luckfox Pico
Execute the following command on the target platform, replacing <HOST_IP> with the host's IP address, <PORT> with the port number gdbserver is listening on, and <YOUR_PROGRAM> with the executable you want to debug:
This will start gdbserver on the Luckfox Pico, listening for connections from GDB.
2. Start GDB on the host
On the host machine, use GDB with the same architecture as the target platform. Execute the following command:
Once in GDB, execute the following command, replacing <DEVELOPMENT_BOARD_IP> and <PORT> with the IP address and listening port number on Luckfox Pico:
This will connect GDB to the remote gdbserver.
3. Run debugging commands on the host
Use standard GDB commands for setting breakpoints, single-stepping, etc. For example:
gdbserver <HOST_IP>:<PORT> <YOUR_PROGRAM>
For example:
gdbserver 192.168.10.99:1234 test
arm-rockchip830-linux-uclibcgnueabihf-gdb
target remote <DEVELOPMENT_BOARD_IP>:<PORT>
For example:
target remote 192.168.10.100:1234
- Set a breakpoint: break <function_name>
- Single-step: step
- Continue execution: continue
Remote debugging with GDB+gdbserver
For example:
For example: launch.json for VScod
For example:
gdbserver 192.168.0.11:2000 hello
file ./hello
target remote 192.168.0.11:2000
// Use IntelliSense to learn about possible attributes.
// Hover to view descriptions of existing attributes.
// For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
"version": "0.2.0",
"configurations": [
"name": "Remote Debugging",
"type": "cppdbg",
"request": "launch",
"program": "${workspaceFolder}/build/hello", // Шлях до вашого виконуваного файлу на цільовому пристрої
"args": [],
"stopAtEntry": false,
"cwd": "${workspaceFolder}",
"environment": [],
"externalConsole": true,
"MIMode": "gdb",
"miDebuggerPath": "arm-rockchip830-linux-uclibcgnueabihf-gdb", // Шлях до вашого виконуваного файлу GDB на вашому хості
"miDebuggerServerAddress": "192.168.0.11:2000", // Адреса та порт вашого віддаленого GDB-сервера
"setupCommands": [
"description": "Enable pretty-printing for gdb",
"text": "-enable-pretty-printing",
"ignoreFailures": true
"serverLaunchTimeout": 5000,
"filterStderr": false,
"filterStdout": false,
"targetArchitecture": "arm" // Архітектура цільового пристрою
I use the following command to transfer the test program
in the terminal it shows that it is copied, but in fact it is not.
Сan someone help how to correctly copy the program to the development board?
scp -r /home/uzfm/test root@192.168.0.9:/root/test
The command you executed seems to have no errors. If 192.168.0.9 is the IP address of the development board, and the transfer is showing as successful on the host, you should be able to see the file on the development board.
Please verify whether 192.168.0.9 is indeed the IP address of the development board, or try changing to another transfer method:
https://wiki.luckfox.com/Luckfox-Pico/L ... -Transfer/
I checked everything.
Maybe it sees that the catalog already exists and does not update it?
1. Use the buildroot image provided by the network disk.
2. Ensure that the host and the development board are on the same local network and can ping each other.
3. Use SSH for the transfer.
When I try to run the program, it ends.
Can anyone help with this problem?
There was a problem when debugging the rknn_yolov5_demo program. the program is compiled and works well, but when debugging there is a problem.
This is from visual code.
Debugging information is present.
command (l ) starts to show information from the end of main.
This is from the terminal
opencv-mobile example debugs great!
The debugging issue arises when using the librknnmrt.so library.
Process /root/RV1106_RV1103/rknn_yolov5_demo/build/rknn_yolov5_demo created; pid = 2794
Listening on port 2000
Remote debugging from host 192.168.0.18, port 51596
/root/RV1106_RV1103/rknn_yolov5_demo/build/rknn_yolov5_demo: can't load library 'librknnmrt.so'
(gdb) target remote 192.168.0.5:2000
Remote debugging using 192.168.0.5:2000
Reading symbols from /home/uzfm/luckfox-pico/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/arm-rockchip830-linux-uclibcgnueabihf/sysroot/lib/ld-uClibc.so.0...(no debugging symbols found)...done.
0xa6fe9138 in _start () from /home/uzfm/luckfox-pico/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/arm-rockchip830-linux-uclibcgnueabihf/sysroot/lib/ld-uClibc.so.0
(gdb) continue
Continuing.
[Inferior 1 (process 758) exited with code 020]
Can someone explain what the problem is when debugging?
