I need to get video stream H.264 encoded since recorder I'm evaluating is support H.264 only.
By default rkipc is outputting H.265 video.
I tried to read chinese docs (MPI doc is not available in english) but I failed to find how to do it.
So question is: How to force rkipc to generate H.264 video ?
Switch rkipc to output H.264
Hello, to modify rkipc to output H.264, you can change the output_data_type under the [video.0] node in the /oem/usr/share/rkipc-300w.ini file to H.264.
