Sometimes after launching my program with RkLunch-stop.sh execution at the start, the system freezes after printing "Stop Application ..." for around 10 seconds and then reloads without any messages. Moreover, I cannot connect to Pico Pro Max via SSH after that until unplugging and plugging the plate in PC again.
What may be the possible issue?
Luckfox freezes and reloads after RkLunch-stop.sh execution on Pico Pro Max
Hello, when executing RkLunch-stop.sh, the udhcpc process will be shut down. If the board has not obtained an IP address at this time, it may cause SSH to be unable to log in. If you just want to close the camera usage, you can use the command "killall rkipc" instead.
I noticed that you have already reported that you have solved the problem in the latest post. If the problem with your program running failure still exists, please provide the printout information of the running terminal to facilitate further problem localization.
