Access KVM on vLAN
  • Network environment configuration can be quite complex, and based solely on your description, I am unable to determine the exact situation. Generally speaking, as long as the client can access port 80 of the PicoKVM's IP address, and the PicoKVM itself has outbound network permissions, a connection can usually be established. Being on the same subnet is not the only requirement for accessing the PicoKVM. I would suggest first checking whether 10.0.0.10 and 10.0.44.10 can ping each other successfully.
