各位大神们好,我用自己编译的OPENCV4.8.0打开SC3336摄像头,图像显示异常:
cv:Mat buf, im;
this->pCap->open("/dev/video11");
this->pCap->set(cv::CAP_PROP_FRAME_WIDTH, width);
this->pCap->set(cv::CAP_PROP_FRAME_HEIGHT, height);
(*this->pCap) >> buf;
if(buf.empty()) {
LOG(ERROR) << "Nothing!";
return false;
} else {
cv::cvtColor(buf, im, cv::COLOR_YUV2BGR_UYVY);
LOG(INFO) << "Image width: " << im.size().width << " height: " << im.size().height;
return true;
我想问下,rk1106对摄像头操作是否还有前置的初始化过程?
改用OpenCV-mobile-4.9.0后,无法获取到图像:
fat32 wrote: ↑2024-02-05 15:47
有注意用 killall rkipc 关闭rkipc进程吗,opencv-mobile用到mpp库和系统开机运行的rkipc冲突
是的,确认rkipc已经kill,进程中已不存在rkipc
这是我之前编译的4.9.0版本的,测试捕获一帧图片,你可以试一下
Downloaded 985 times
测试你这边编译好的opencv-mobile-test也是一样的
我自己的也是同样情况:
进程情况:
# ps -ef
PID USER COMMAND
1 root init
2 root [kthreadd]
4 root [kworker/0:0H]
6 root [mm_percpu_wq]
7 root [ksoftirqd/0]
8 root [kdevtmpfs]
9 root [oom_reaper]
10 root [writeback]
11 root [kcompactd0]
12 root [ksmd]
28 root [kblockd]
29 root [kconsole]
30 root [devfreq_wq]
31 root [watchdogd]
33 root [rpciod]
34 root [kworker/u3:0]
35 root [xprtiod]
36 root [kswapd0]
37 root [nfsiod]
38 root [irq/64-rockchip]
39 root [irq/65-rockchip]
40 root [irq/66-rockchip]
42 root [hwrng]
43 root [spi0]
51 root [stmmac_wq]
54 root [irq/21-RTC alar]
55 root [irq/23-rockchip]
56 root [kworker/u2:2-ev]
57 root [ubi_bgt0d]
60 root [ubifs_bgt0_0]
76 root /sbin/syslogd -n
80 root /sbin/klogd -n
91 root /sbin/udevd -d
148 root [ubi_bgt4d]
153 root [ubifs_bgt4_0]
162 root [ubi_bgt5d]
167 root [ubifs_bgt5_0]
189 root [irq/51-ffa70000]
207 root [irq/42-rga2]
209 root [queue_work0]
210 root [queue_work1]
211 root [irq/49-ffa50000]
212 root [irq/50-ffa60000]
213 root [vcodec_thread_0]
215 root [rknpu_power_off]
222 root sshd: /usr/sbin/sshd [listener] 0 of 10-100 startups
244 root [vlog]
248 root [vsys]
249 root [vrga]
250 root [vpss]
251 root [vrgn]
252 root [vmcu]
347 root /usr/bin/adbd
373 root [irq/67-dwc3]
397 root [venc]
424 root smbd -D
427 root {smbd-notifyd} smbd -D
428 root {smbd-cleanupd} smbd -D
434 root nmbd -D
439 root /sbin/getty -L console 0 vt100
442 root [kworker/0:3-eve]
465 root udhcpc -i usb0 -T 1 -A 0 -b -q
473 root /bin/sh -l
544 root /bin/sh -l
950 root [kworker/u2:0-ev]
1118 root [kworker/0:0-eve]
1576 root ./opencv-mobile-test
1587 root [kworker/0:1]
1677 root ps -ef
fat32 wrote: ↑2024-02-06 14:26
我自己的也是同样情况:
进程情况:
# ps -ef
PID USER COMMAND
1 root init
2 root [kthreadd]
8 root [kdevtmpfs]
9 root [oom_reaper]
10 root [writeback]
12 root [ksmd]
28 root [kblockd]
29 root [kconsole]
31 root [watchdogd]
33 root [rpciod]
35 root [xprtiod]
36 root [kswapd0]
37 root [nfsiod]
42 root [hwrng]
43 root [spi0]
51 root [stmmac_wq]
57 root [ubi_bgt0d]
244 root [vlog]
248 root [vsys]
249 root [vrga]
250 root [vpss]
251 root [vrgn]
252 root [vmcu]
397 root [venc]
424 root smbd -D
434 root nmbd -D
473 root /bin/sh -l
544 root /bin/sh -l
1677 root ps -ef
你的系统是在 SPI NAND Flash 上的还是 TF 卡上的,我在 luckfox-pico plus TF 卡上运行的结果:
之前也遇到过运行不了的情况,似乎和 DMA 有关,很遗憾我没记录下来
是在SPI NAND上运行的,不过如果SPI NAND有DMA冲突的话,那rkipc那个也应该要有问题才是
